Folks,
cannot describe how chuffed I am to have found this page
..... been searching in Vortex and ukmkivs ..... no luck at all.
To contribute my share, I have consolidated what have been discussed. So that anyone like myself looking for MK7 tweaks is able to benefit from the great works you guys have put in!! (hope you guys don't mind.....
1. Amount of fuel (in Gallons) used since the last fill up
Go into [17] Instruments
Long Coding - (Function 07)
Go to Byte 10
Enable bit 4
2. Password to unlock [09] Central Electronics Menus
Go into Function 16 (Permissions)
Enter the code 31347
3. Disable Seatbelt Warning
Adaptation Channels -> function 10
Select disable seatbelt warning (Gurtwarner deaktivieren)
change to "yes" (default: none)
4. Setting Fog Lights as Coming/Leaving Home
Go into [09] Central Electronics
Go into Security Access and enter 31347
Look for the German text under "Comfort-Illumination"
Set the new value drop down to "Fog Light"
5. Display the battery charge level or SOC (state of Charge)
Enter [17] Instruments
Go to adaptation channels, (no need for a security log in with this module)
Scroll down until you see Battery Charge > simply change it in the new value drop down to "active" and it's done.
Usage
Switch the ignition off, then press (and continue to hold) the trip reset button in the middle lower of the instrument panel. It will cycle from first resetting the trip to 0 miles > show "Time" to allow you to change the clock > then keep holding until say "Battery".
Release the button and display SOC for a few seconds before returning back to the main screen.
6. Automatic rain closing
Go into Secuity Access and enter 31347
Go to adaptation channels and set the following:
- (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
- (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
- (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the ifotainment screen)
7. Alarm beep on lock / unlock
Adaptation channels, and you are looking for:
(1)-Acknowledgement Signals -Akustische Rueckmeldung entriegen (un-lock acoustic feedback)
(2)-Acknowledgement Signals -Akustische Rueckmeldung verriegeln (lock acoustic feedback)
Set one or both to on if you wish.
Then set the following to "on"
(7)-Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung (Acoustic lock menu)
This enables a menu setting in the "car" settings, "Locking" menu of the infotainment screen to set alarm chirp on or off when locking /unlocking the car and have the option to switch it on or off from the head unit.
8. Gauge sweep
Coding -> Function 10
Byte 1
Enable bit 0
9. Side mirrors fold?? (under investigation)
With regards the mirrors, there are a couple of options and the one that interests me is -
(24) Access Control 2 - Funk Spiegelanklappen Modus (mirror folding in remote mode), Need to have a bit of a play around with this one to see if the possibility of unfolding on keyfob press (rather than ignition) exists ?
10. Change XDS interaction to strong
……. Cannot find the steps… oops! :0)
