Author Topic: Great blog post about SD card usage in the Mk7  (Read 38633 times)
Offline Rick101
Re: Great blog post about SD card usage in the Mk7
« Reply #10 on: 26 April 2014, 09:15 »
I've downloaded the station logos from VW site in readiness. As I understand it you you allocate the logos to each station manually and then can remove the SD card. Thats suggests the logos are held in the cars internal memory.
How many station logos can the car hold in memory??
Thanks.
Offline mcmaddy
« Reply #11 on: 26 April 2014, 22:15 »
15 or 18 I can't remember which.
Offline Talk-torque
« Reply #12 on: 09 May 2014, 07:30 »
I'll prob need some help with this. What size card you use as a minimum?
Say for 40 albums/500 average tracks?
You'd certainly get that onto a 4GB, SDHC card, but an 8GB won't cost much more and will give you scope for adding more. (You will want to!)
Roger.
Offline p9ul
« Reply #13 on: 17 May 2014, 14:41 »
Thanks.
15 stations can be stored for each of DAB, FM & AM - you can assign a logo to each so 45 in total.
Offline sam1014
« Reply #14 on: 28 June 2014, 08:26 »
Hi guys, with regards to the SD card or USB stick, whats better to use? Or is it simply just personal preference? I generally use mini usb sticks for normal use, so i was just going to use one of them.
I've seen a 64gb Sandisk mini usb stick for £23.95  -  BARGAIN!!
GTI ON ORDER!!….
Offline Ross Detours
« Reply #15 on: 04 July 2014, 15:15 »
64GB SD card - £20
I believe you don't get a USB connection unless you have spec'd the discover nav system.
http://www.amazon.co.uk/Transcend-Premium-Memory-Frustration-free-Packaging/dp/B004XIB9T6/ref=sr_1_2?ie=UTF8&qid=1404482838&sr=8-2&keywords=64gb+sd+card
Offline 914Phil
« Reply #16 on: 04 July 2014, 20:21 »
I'm struggling a little with one part of this, I have done the station logos no problem other than having to format to fat32 as per one of the comments under the blog post. Now onto music and using media player have got music to the SD card but no album artwork. The artwork is showing on the media player on my PC. appreciate any ideas anyone has to assist?
