3 years ago my then nearly 5 year old golf had a new engine due to the old one seizing as STOP Engine OFF Oil Pressure came on and I foolishly kept driving to get home! nearly 3 years into a new engine regularly serviced and it happens again so stopped this time did so research found it could be oil pick up pipe....took to mechanic who found this was blocked and full of gunk and the oil like treacle....he fixed the issue last Tuesday then today the light came on again after more research seemed it could be a sensor. After the light going off and coming on again and about 2 miles of driving the engine stopped Had to be towed home as wouldn't restart .... oil is fine so just hoping won't be the engine gone again!!!!! Any ideas??
What engine have you got?
Pick up pipes blocking were a problem on the MK4 1.8T but there have been a couple of cases on the 2.0l TFSI documented on the MK5 forum.
How was the issue fixed with the first blockage? Was the original pickup pipe replaced?
It's hard to say over the internet and you did the right thing by not driving it this time.
It could be the Sensor/Wiring/pump.
I would be interested to know what oil you're using and what Mileage/Interval you change the oil and filter.
There is potentially a higher risk of sludge formation with longer oil change intervals and of course oil quality.
