The garage
Diagnostics - VagCom / VCDS
Rhyso
Boost spec vs actual log
Topic: Boost spec vs actual log (Read 5858 times)
Chris.
Re: Boost spec vs actual log
Reply #10 on:
23 February 2013, 15:10 »
Definitely in limp mode. 5% duty cycle is what you see when in limp.
MAF sensor could be a bit out too.....is it any better if you unplug the sensor?
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
novadragon007
GTI forum regular
Love at first clutch bite...
Reply #11 on:
23 February 2013, 15:17 »
it doesnt change if i unplug the maf and im not sure how far i can drive it with it unplugged. is it safe to go a run with it unplugged. it still feels quite powerful and no engine light on at all
Mk4 GTi 1.8t 16" BBS Alloys, Coilovers, Full Exhaust, Catch can..... More to come - If i ever beat this 17705
novadragon007
GTI forum regular
Reply #12 on:
23 February 2013, 15:32 »
also i just replaced the n75 should i clear the ecu before logging as battery wasnt disconnected to replace it was just a swap over.
The garage
Rhyso
