The garage
Diagnostics - VagCom / VCDS
Rhyso
north east member with vagcom needed to code in my mapped ecu
Topic: north east member with vagcom needed to code in my mapped ecu (Read 5101 times)
0138hutchy
01 February 2013, 21:41 »
The above needed will provide a bit of coin for your trouble
Chris.
Re: north east member with vagcom needed to code in my mapped ecu
01 February 2013, 22:02 »
What engine code mate. im 2 miles from bishop.
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
0138hutchy
01 February 2013, 22:06 »
Agu mate got a standard ecu in atm looking to put my mapped one in once I get my hybrid ko4 in and few other bits n pieces fitted ecu is from the same car as all the bits
Chris.
01 February 2013, 22:07 »
Ahhh, should be able to do it...laptop doesnt hold its charge very well but can plug it in. Any help with the bits i can help you out :p
0138hutchy
01 February 2013, 22:14 »
Where about u live like bud?
Chris.
01 February 2013, 22:15 »
Hunwick.
0138hutchy
Reply #6 on:
01 February 2013, 22:16 »
Am from crook like so just up tha road
0138hutchy
Reply #7 on:
01 February 2013, 22:20 »
So you reckon u will be able to sort the ecu problem I have easy to do like?
Chris.
Reply #8 on:
01 February 2013, 22:25 »
Should be....immo 2 is very easy to code in....if later clocks bit harder.
0138hutchy
Reply #9 on:
01 February 2013, 22:27 »
Ok so once a get sorted I will message u and go from there... cheers for the reply what car u got like? Might of seen u about?
The garage
Rhyso
