Author Topic: Fault code 01314 Please look and advise :S  (Read 17690 times)
Offline Chris#101
« on: 28 January 2013, 18:18 »
Right following on from my last topic with the erratic idle/loss of power etc
 http://www.golfgtiforum.co.uk/index.php?topic=247350.0
the car is a 2003 Golf GTI AUQ 180 with an R-tech Stage 2 live custom remap
If I unplugged the maf the car ran alot smoother but just underpowered. so Ive just gone an brought a new maf from VW and it hasnt made a wanks worth of difference exactly as lumpy and boggy as before  :rolleyes:
SO Ive just scanned my car and I have the following fault code 01314 which wasnt there last time and I cant physically delete it  :lipsrsealed:
Copied of Ross tech
01314 - Engine Control Module
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Engine Control Module recently flashed or re-mapped
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB) Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
Check Engine Control Module for Fault Codes
Special Notes
Engine Control Module stored a Code which influences other Control Modules Functionality.
 To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
What the hell does this mean It sounds quite serious and expensive  :sick:?
please advise
« Last Edit: 28 January 2013, 18:20 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
Re: Fault code 01314 Please look and advise :S
« Reply #1 on: 29 January 2013, 07:30 »
Anyone? :cry:
Offline Dalo Harkin
« Reply #2 on: 29 January 2013, 08:52 »
sounds like your ECU mate, has this happened recently or has the map been changed recently?
These ECUs are not common to go
Offline gt130dave
« Reply #3 on: 29 January 2013, 08:55 »
Ross-Tech, LLC
881 Sumneytown Pike
Lansdale PA 19446, USA
Tel: +1 267 638 2300
Fax: +1 215 893 3816
Skip to content
Shop
Info
F.A.Q.
Download/Update
Manual
Upgrades
Literature
Search:
01314
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 01314 - Engine Control Module
1.1 01314 - Engine Control Module: No Communications
1.1.1 Possible Causes
1.1.2 Possible Solutions
1.2 01314 - Engine Control Module: Check DTC Memory
1.2.1 Possible Causes
1.2.2 Possible Solutions
1.2.3 Special Notes
Possible Causes
Possible Solutions
Possible Causes
Possible Solutions
Special Notes
Retrieved from "http://wiki.ross-tech.com/wiki/index.php?title=01314&oldid=5027"
Category: Fault Codes Categories
Main Page
Diagnostic Procedures
Common Procedures
Fault Codes
Retrofitting
Immobilizer
Meta
Log in
Hope this helps m8
Offline Chris#101
« Reply #4 on: 29 January 2013, 10:24 »
[/quo
had the r tech remap from arounf august last year and has been no.troublw since then. This problem.occured when we had all tge.snow and.rain when abs and traction control were constany ki,king in!?
Offline Nino
« Reply #5 on: 29 January 2013, 11:01 »
Im not an expert but it dwfo sounds like there is something wrong with the ecu, call r-tech and have them take a look, mught be garanteed :)
VW Car history
Mk3 1.8 GL - Silver - 5 door
Mk4 1.8t - Silver - 3 door
Mk4 R32 - Black - 5 door
Mk5 GTi - Black - 5 door
Mk4 R32 - Deep Pearl Blue - 3 door
MK6 2.0 TDI - Graphite Blue - 5 door
MK7 GTD - Solid Black - 5 door
MK6 GTi Edition 35 - Candy White - 3 door
Offline Dalo Harkin
« Reply #6 on: 29 January 2013, 12:33 »
have you physically looked at the ECU to see if it 'looks ok' and no wires damaged/wet
be VERY careful when you take the scuttle off because people have smashed/cracked their windscreen trying to get to the ECU
