Author Topic: What have you done to your Mk6 today then?  (Read 647177 times)
Offline Jimble
Re: What have you done to your Mk6 today then?
« Reply #540 on: 05 June 2013, 21:44 »
Filled a few stone chips ready for sanding back at the weekend!! :sick:
Offline cosmicremedy
« Reply #541 on: 06 June 2013, 16:17 »
Filled with paint and then flattened off?
Offline Jimble
« Reply #542 on: 06 June 2013, 17:57 »
Yup! Had a go at them tonight but i think i need to put a little more paint in them as when the paints cured it's shrunk quite a lot so sits too low, grrrrr >:(
Offline ajmoir36
« Reply #543 on: 06 June 2013, 20:40 »
What are you going to use to sand them back, i have been wondering whether a machine polisher with the right pad might be good at it.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline jhunter_83
« Reply #544 on: 06 June 2013, 21:16 »
Well after my smokey engine last week which I thought that my turbo had gone,
After an inspection the garage is pretty certain it was down to the PCV system putting oil into the intake system and pressurising the crank, so decided to fit a Forge catch can, will be testing it out properly on Friday to see if this has solved the problem  :smiley:
Kit is a perfect fit and everything needed to complete the job
Parts removed
So what happens with the washer bottle spout?
2010 Silver Golf GTi 5 Door, Poverty spec wheels, RCD510 Bluetooth and DAB, Pagid Discs and Tarox Strada Pads
Offline Neil gti
« Reply #545 on: 06 June 2013, 22:25 »
^^^^ the small round cap next to the catch tank is the new washer filler neck,
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline RocketRossUK
« Reply #546 on: 06 June 2013, 22:34 »
does the TSI engine even need a catch can system, thought it was pretty good at holding oil and not building up.
Offline Poached
« Reply #547 on: 06 June 2013, 22:44 »
Haven't heard of any TFSI or TSI engines having performance problems as a result of not fitting a catch can.
Offline Poached
« Reply #548 on: 06 June 2013, 22:46 »
Just sent my super chips unit off to be reset. It has to be sent off so will cost £232.50.
Cheaper than starting again
Surely for £290 a R-Tech Custom Map would have been a better choice. But let us know how you get on :)
R Tech don't currently offer TSI software, they will put Revo software on.
Offline Neil gti
« Reply #549 on: 06 June 2013, 23:00 »
The PCV is prone to failure and I think that was causing my car to smoke when it is really pushed, so I thought I'd get rid of the pcv and fit a can,
http://www.forgemotorsport.com/content.asp?inc=product&cat=&product=FMCT2
Loving the 7R
