« Reply #378 on: 08 May 2013, 18:37 »
My near side wiper is sitting an inch or so higher than it did before I had the windscreen replaced too. Do you know how to correct this?
Take the wiper arm off (being careful not to damage the bonnet) and move it clockwise by a couple of splines.
A little more info.
Put the wipers into service mode. (Ignition on then off and push down once on the stalk).
Open the bonnet.
Use an small screw driver in the notch provided to lift off the cap concealing the wiper arm nut.
Use a 13mm or spanner to remove nut.
I used two other spanners to place under the wiper arm to leave it off. It was well jammed on after the engineer had tightened it up.
Align the wiper arm about 1 inch from the side of the windscreen, place on splines loosely do up the nut.
Close bonnet trying not to crush any tools or fingers.
Ignition on push stalk down once. Wipers should park perfectly.
Open bonnet tighten nut.
Replace cap
Close bonnet
Pat on back for job well done.
Diagonally parked in a parallel universe.
Now: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone but not forgotten: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio + DAB, Cruise, Winter Pack, Luxury Pack and TPS.
