Author Topic: Why use vag com?  (Read 3921 times)
Offline Mach 5
Why use vag com?
« on: 10 January 2013, 18:55 »
Hi all, I'm new to vag cars. Have always had jap cars until now!
Can someone briefly explain why bag com is needed? You can buy equipment on eBay that reads and resets fault codes for as little as £20. What does vag com do over and above this that makes it worth it's money?
Cheers.
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
Re: Why use vag com?
« Reply #1 on: 10 January 2013, 19:13 »
Be careful what you buy on ebay as there is limits to what the gear can do.The VagCom from RossTech is expensive but its all singing and dancing and can be updated and you can reset everything.
Rob
« Reply #2 on: 31 January 2013, 10:48 »
A handheld scanner will do most things icluding clearing codes as required.
Offline Rhyso
« Reply #3 on: 31 January 2013, 12:41 »
Rob
Lifetime product support, updates to the latest version.
You can use it to code new modules, clocks etc.  Also you can do live data logging to on the engine.  You can code up certain features, alter parameters etc etc.
Can the scanner do ALL of the above?  :huh:
Yes VAGCOM is expensive but look at it this way.  Every time you take your car to a garage or VW they charge you to look at it.  Visit 3/4 times and VAGCOM has already paid for itself in diagnostic fees
Also you can earn beer tokens from anyone local to you  :wink:
« Reply #4 on: 31 January 2013, 13:26 »
Nope, I worded my post a little wrong, the ebay ones will do the basics but Vagcom is still the best bet and as you said it can also earn you money.
I know on my Skoda it was not running right yet the light was not on and no codes were showing on the handheld unit I had, you kindly scanned it at combe and it was showing 3 fault codes.
