Author Topic: Colour Concept heated seats  (Read 3182 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
Re: Colour Concept heated seats
« Reply #10 on: 01 December 2012, 11:57 »
Ok,so ive been out to the car this morning to have a play with the switch.Had it all out the dash,the bulb seems to be a resistor type bulb,so will need to source a new one of these and a solder iron to replace this.As regards to hearing any relays clicking when turning the heated seats on,i can hear it click on the passenger side seat when turning on at the right hand side of the control switch and a click from which sounds like from behind the dash when turning on at the left hand side of the control switch.
Offline Mr Blue
« Reply #11 on: 01 December 2012, 13:47 »
I have a similar issue. If i use the driver side switch, both relays click. Nothing from the passenger side.
I can't compare the switch as I don't have another but I suspect its the switch.
 :smiley:
Offline Leebob
« Reply #12 on: 01 December 2012, 14:15 »
Do you think the driver side switch turns on both seats and the passenger side switch just controls the temp for the passenger seat then?
Offline Joey16v
« Reply #13 on: 30 October 2019, 14:39 »
I'm having the same problem anyone any help on this I know this post is years old but I can't find the answer.  Thanks
