Author Topic: Interior lights and side repeaters  (Read 1633 times)
jockgti
« on: 05 August 2012, 18:31 »
right last 2 days i've had my drivers side door in bits thinking it was door module problems(which it may still be),but having put it all back together i still have same problems,drivers side puddle light not working,light behind drivers side sun visor mirror not working,main lights that are supposed to come on when door opens not working,side repeaters not working even when hazards are used all other indicators work fine,passenger side puddle and sun visor light work ok.so am i still looking at door module issues? cheers for any help
Offline GTi_James
Re: Interior lights and side repeaters
« Reply #1 on: 05 August 2012, 20:56 »
i know this is going to sound wierd but i had the same problem, thought it was wiring but i had the engine management light come on once so zipped to my local garage, plugged the old doo-dah in and cleared the code (engine splutter) and as soon as he deleted it all my interior started working as if it was back from holiday, may be worth a shot?
jockgti
« Reply #2 on: 05 August 2012, 21:03 »
i've got a code reader here and don't have and codes up
Offline GTi_James
« Reply #3 on: 05 August 2012, 21:35 »
then im stumped lol
jockgti
« Reply #4 on: 06 August 2012, 22:11 »
do tps sell modules? and is there any difference in modules 3 door 5 door year of car?
Offline james2
  • No scammers please.
« Reply #5 on: 06 August 2012, 22:22 »
you tryed new bulbs in side repeaters? puddle light will be the door mod. The switch gets stuck in it, i got a + screw driver and on your door lock theres 2 big screws ,put the screw driver in the bottom one and hit it with a hammer until your puddle light comes on.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
jockgti
« Reply #6 on: 06 August 2012, 22:31 »
yeah tried new bulbs
Offline james2
« Reply #7 on: 06 August 2012, 23:24 »
check fuses.  :undecided: i know your puddle light and int lights the door mod unit. Im thinking your side indicators is a wiring fault, fuse or flasher unit prob not flasher unit or bad connection to it. Try and pick up one from scrap yard. Do both front side indicator not working.
Offline james2
« Reply #8 on: 06 August 2012, 23:27 »
if so and no fuses gone get second hand flasher unit or rewire so they join on the front indicators.
Offline GunnerCP
« Reply #9 on: 07 August 2012, 00:42 »
3 and 5 door appear the same.... You could just solder your current one?
