Author Topic: INTERCOOLER  (Read 6784 times)
Offline markgti1.8t
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Dalo Harkin
Re: INTERCOOLER
« Reply #1 on: 03 July 2012, 06:21 »
It says 2.25" inlet and outlet but the tubing is only 2" and this isnt ideal really you'll want 2.5" tubing and none on ebay have that
« Last Edit: 03 July 2012, 07:14 by Dalo Harkin »
Offline turbokid23
Re: INTERCOOLER
« Reply #2 on: 03 July 2012, 08:39 »
Real bad fit mate
Offline stfc_gti
Re: INTERCOOLER
« Reply #3 on: 03 July 2012, 11:48 »
in short NO.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Chris#101
Re: INTERCOOLER
« Reply #4 on: 03 July 2012, 12:32 »
Im going to disagree, Mines a toyosports F.M.I.C kit although it looks identical to that, infact the pictures is exactly the same!
With a bit of time and effort you can get it to fit relatively well
R-tech Managed to get 231bhp and 258lbs out of the restrictive 1.75" pipework from the turbo to intercooler. As soon as I get this selection of pipework changed to 2.5" R-tech says another 10bhp will easily be achieved
So in conclusion.... If you dont want to save yourself alot of money and a bit of time and want a direct fit go and by a Forge or THS for 3times + the amount for a direct fit! How ever the latter option didnt appeal to me for obvious reasons
« Last Edit: 03 July 2012, 12:35 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline cullygti
Re: INTERCOOLER
« Reply #5 on: 03 July 2012, 12:38 »
chris when people say it dont sit very good they are refering to the pipework as its hard to fit them behind the grills not the core itself i had one and took it off due to not being able to hide the pipes behind the grill  :smiley:
i dare say with a bit more patience i could have done it but it done my head in  :grin:
« Last Edit: 03 July 2012, 12:44 by cullygti »
Offline jamie1989
Re: INTERCOOLER
« Reply #6 on: 03 July 2012, 12:47 »
I struggled and ended up looking like the above and also had the pipe work painted black to make it look abit more oem but still werent happy.
Although its a fraction of the cost of well known brands and does the same job as them and still looks quite cool when times been spent on them.  :smiley:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline shaft69
Re: INTERCOOLER
« Reply #7 on: 03 July 2012, 14:11 »
A lot of the cheap ones not bar and plate core so not that good for cooling as to bar/plate core.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline markgti1.8t
Re: INTERCOOLER
« Reply #8 on: 03 July 2012, 21:29 »
do you not think i should get this one then thanks
Offline jamie1989
Re: INTERCOOLER
« Reply #9 on: 03 July 2012, 21:48 »
I wouldnt say dont get it.
Its your choice and your budget.
Iv had one and it done the job I want to save for a THS one but thats me being snobby and purely for cosmetic reasons.
