Author Topic: Headlining reupholstery complete  (Read 50359 times)
Offline mikemk4gti
Re: Headlining reupholstery complete
« Reply #10 on: 25 April 2012, 19:03 »
Got the stuff to do this in the post today. The old headlining is out but one corner has broken off :(
 Anyway hopefully be able to fix that, but someone has tried glue on it before and the back half has loads on which ain't coming off, hoping it'll be ok.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline scottishpedro
« Reply #11 on: 25 April 2012, 21:12 »
My headlining had lots of cracks etc, as long as it is taped up from the back and the broken bit is being held in the correct position, the whole thing will be much more solid/reinforced when the material is on.
Keep us updated on your progress
Offline mikemk4gti
« Reply #12 on: 26 April 2012, 19:33 »
Decided to get on with this after work today, with the help of this guide it went well.
Couldn't get the old glue off as it was pulling the polystyrene stuff off with it.
Did it in two halves, and worked it well into the recesses
After trimming around the edges it ended up like this.
The acoustic carpet is really good stuff, and easy to get to shape how you like.
Not refitted to the car yet as its p***ing it down out there
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 26 April 2012, 19:37 »
Looking Good!!
For More Info Click To See;
« Reply #14 on: 27 April 2012, 22:42 »
Great job, it looks just like mine did!  Yeah the acoustic carpet was just a best guess at what would work and it seems perfect for the job.  I'm glad you have found the guide useful.
Pedro
« Reply #15 on: 27 April 2012, 22:45 »
Re the glue used previously to stick the headlining up; I could not get all of ti off mine and there seems to have been no issues.
Offline mikemk4gti
« Reply #16 on: 27 April 2012, 23:07 »
I put it back in the car this evening, really pleased with it. Could of done with a helper bit not essential. Might consider doing the sunroof panel too
Offline mikemk4gti
« Reply #17 on: 28 April 2012, 16:26 »
And here it is
Really pleased with it!
 Need to do the sunroof panel aswell really but I haven't got enough material left.
« Reply #18 on: 29 April 2012, 09:20 »
Looks really good, great job!
Offline Jamtarts
« Reply #19 on: 18 June 2012, 10:31 »
what a brilliant guide!!! Thanks for posting this, :D
my headlining has come away at the back and starting to come away at the front, it's a bit saggy in the middle.  I'm hoping to use the original material, I'm psyching myself up to take this on.
If i take it out and it take me longer than expected to complete it, is the car still driveable with this removed? (is it legal?) maybe a silly question, but just to check whether to put it off road until completed.
I assume I can just use the original material or is this likely to rip when removing it?
Is there anyway I could just spray glue in and flatten all down without removing it all and only removing the areas I need access to?
sorry for all the questions, I was just hoping to be better prepared before I started,
