Author Topic: 17511 and 17524  (Read 5452 times)
17511 and 17524
« on: 12 March 2012, 16:25 »
These 2 codes are coming on, I can clear them but 2 miles later they are back on.
Just to confirm, is this for the front lambda sensor.
« Last Edit: 12 March 2012, 16:28 by Wayne »
Offline barrym381
Re: 17511 and 17524
« Reply #1 on: 12 March 2012, 19:59 »
That's the Lambda sensor (O2 sensor) in front of the catalyst.had the same with 1 of my golfs was the wire broke :smiley:
Re: 17511 and 17524
« Reply #2 on: 12 March 2012, 21:10 »
Thanks for confirming it, it is booked in on Weds just wanted to check so they can order the parts in ready.
Offline Keithuk
Re: 17511 and 17524
« Reply #3 on: 29 May 2012, 02:00 »
VAG Error Code: 17511
EOBD II Error Code: P1103
Fault Location:
Heated Oxygen Sensor (HO2S) 1 (G39), Bank 1 - Heater Output too Low
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) Triggered on first occurrence.
Wiring.
Heated oxygen sensor (HO2S) (G39).
Possible Solutions:
Check Oxygen Sensor (O2) Heated oxygen sensor (HO2S) (G39) before Catalytic Converter.
VAG Error Code: 17524
EOBD II Error Code: P1116
Fault Location:
Heated Oxygen Sensor (HO2S) 1 (G39), Bank 1 - Heater Open Circuit
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) ON.
Fuse(s) faulty.
Wiring short to earth.
Wiring and/or Connector(s) from/to Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19) faulty.
Possible Solutions:
Check Fuse(s).
Check Wiring and/or Connector(s) from/to Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19).
Check/Replace Oxygen (Lambda) Sensor (G39) / Oxygen (Lambda) Sensor Heating (Z19). Wiring open circuit, HO2S
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
