Author Topic: 12 years SORN  (Read 993 times)
Offline iain cooper
12 years SORN
« on: 07 February 2012, 16:21 »
my 8 valve GTI has been in the garage on SORN for about 12 years ( 1987 80000mls and had her since new )
planning to put her back on the road and will need tyres/battery/etc
any tips re starting her for first time after 12 years ?  any advice much appreciated
thanks
Iain
« Last Edit: 07 February 2012, 16:23 by iain cooper »
Offline The Mighty Elvi
  • I'm better than you today.
Re: 12 years SORN
« Reply #1 on: 07 February 2012, 16:32 »
New petrol.
Is the battery ok?
Take off the dizzy cap and give it a good clean.
Take the plugs out and see what condition they are in.
Have a good look around at everything.
It should start after a while, but come back if it doesn't and we'll take it from there.
My other mk2 Golf is 13 years sorn.
 :shocked:
Offline Horney
  • Flippin b!tches, grindin trucks, skatin ditches.
    • Minifinity - For the classic fanatic
Re: 12 years SORN
« Reply #2 on: 07 February 2012, 16:35 »
Spin it over just on the battery for a while to build up oil pressure than crank it with the leads on to fire it up.
Nick
Offline X4MGS
  • Forum Trader
  • VAG Parts SNOB!!!
    • X4MGS153
Re: 12 years SORN
« Reply #3 on: 07 February 2012, 17:07 »
Nick
My Audi S2 was sorned for 6 years and all I did was connect the battery and she fired up 1st time....
But the first thing I did was get a complete service done and got all the fluids changed....
For More Info Click To See;
Offline Mr Blue
  • Moderator
Re: 12 years SORN
« Reply #4 on: 07 February 2012, 17:28 »
Deffo change that oil and fuel as above.  :sick:
Whats the handbreak like?
4/5 door mk2's - Burn them
MK3's, mk4's - burn them
Offline AudiA8Quattro
Re: 12 years SORN
« Reply #5 on: 07 February 2012, 18:34 »
Nick
This.
Remove the fuel pump fuse and centre ignition lead, and crank over on the starter.
Offline SoundillusioN
    • My Music
Re: 12 years SORN
« Reply #6 on: 07 February 2012, 22:08 »
Good point,  mines always off after learning a valuable lesson as a youngen.
Offline Ben Lessani
    • Enterprise Fast Magento Hosting
Re: 12 years SORN
« Reply #7 on: 07 February 2012, 22:45 »
Brake lines tend to corrode from the inside out, so that would be the first thing I'd be changing once its running.
Offline Sam
  • Location: Bomber County, Loughborough, Edinburgh or somewhere inbetween.
  • Sam I am
    • Fatality BMX components
Re: 12 years SORN
« Reply #8 on: 07 February 2012, 23:05 »
If its rubber, replace it. If its liquid, replace it. Simples  :smiley:
Offline Diamond Hell
  • Opinions я Us
    • The Diamond Hell
Re: 12 years SORN
« Reply #9 on: 07 February 2012, 23:10 »
Beter than that - take the plugs out and spin it over to build oil pressure - much less effort needed from the battery.
Brake lines shouldn't be rusted out unless it was left with old fluid in it that was full of water.  :rolleyes:
Get it running, do the fluid changes and be prepared for a couple of breakdowns.
Might be worth changing the cambelt before you do too much - has the most potential to stop the whole shooting match dead in its tracks.
Yes, I probably am going to hell.
But it's warm and I'll be among friends.
