Author Topic: LIST OF PARTS NEEDED FOR 20VT INTO MK3 CONVERSION  (Read 65919 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« on: 29 November 2011, 18:10 »
Here is a basic list of what you will need to carry out the conversion into your beloved MK3
Iv not included prices as these vary.. but you are looking at a few thousand to do the job right.. or if you want me to price it up for you fitted into your car, send me a PM  :wink:
This list is based on, if you are starting out with a GTI 8V as the base car
Best to start with a 16v as you will have many of the parts already
If the base car is a VR6. You will need a 16v Gearbox and clocks
If you start with a lower spec car you will also need in addition to the below, brake upgrade to at least 280mm early GTI / VR6 spec and decent pads to suit
THE LIST:
YOUR CHOUCE OF ENGINE, AGU, AMK, AUM BAM ETC   (make sure it comes with all ancillaries inc Turbo)
ENGINE SIDE LOOM FROM DONOR CAR
ECU FROM DONOR CAR
02A GEARBOX FROM 16V MK3 ETC
REAR DRIVERS SIDE ENGINE BRACKET FROM ABF MK3 16V
FRONT ENGINE BRACKET FROM ABF MK3 16V
GEARBOX MOUNT BRACKET FROM ABF 6V MK3
HYDRO SET UP FROM GOLF MK3 16V GTI / VR6
(Including master clylinder, slave cylinder and piping)
GEAR SHIFTER / CABLES FROM GOLF MK3 16V ABF / VR6
ENGINE MOUNTS (ALL 3) FROM 16V GOLF / VR6 (your choice)
ABF FLYWHEEL
VR6 CLUTCH
16V STARTER MOTOR
CUSTOM DOWNPIPE
SPORTS CAT (If your car requires a cat)
2.5” BORE EXHAUST SYSTEM – JETEX
INTERCOOLER – UNIVERSAL FRONT MOUNT
BOOST PIPES FOR INTERCOOLER
WIRING LOOM MODIFICATION IF REQUIRED TO MAKE PLUG AND PLAY
IMMOBILIZER DEFEAT ON ECU
FORGE 007
SILICONE TIP
MAP SENSOR RELOCATION TUBE (MADE BY FORGE)
VARIOUS OTHER HOSES / BOLTS WILL BE NEEDED
INDUCTION KIT (Of Your Choice)
INDUCTION KIT RELOCATION (optional)
REMAP (Optional)
16v 160MPH CLOCKS (optional)
NEW CAMBELT (optional)
NEW WATERPUMP (optional)
TWIN RAD FAN FROM AIR CON EQUIPPED MK3 ETC (Optional)
SERVICE PARTS: OIL / FILTER / SPARK PLUGS/BRAKE FLUID
TURBO INSPECTION / REBUILD (optional)
MAF SENSOR REPLACEMENT (optional)
COOLANT BOTTLE FROM DONOR CAR , RECOMMEND BUYING NEW (optional)
EARLY CARS REQUIRE LATE CAR PEDAL BOX AND HYDRAULIC FLUID RESOVOIR
SOME ENGINES ARE DRIVE BY WIRE THROTTLE, SO YOU WILL NEED THE ACCELERATOR PEDAL FROM DONOR CAR
« Last Edit: 30 November 2011, 08:54 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Dan_GTi8v
Re: LIST OF PARTS NEEDED FOR 20VT INTO MK3 CONVERSION
« Reply #1 on: 29 November 2011, 18:29 »
Also a map sensor and the fitting tube from somewhere like forge :) and if using the electronic pedal some sort of bracket will need making up
Offline F17BAD
« Reply #2 on: 29 November 2011, 18:42 »
Yeah good point ill add this to the list...
you won't need the tube if you use the one that came with the engine as i did (but then i replaced with the forge one later due to relocation)
billabong
« Reply #3 on: 29 November 2011, 18:49 »
Nice post mate :)
Offline murraymint
« Reply #4 on: 29 November 2011, 19:44 »
sticky? (as 1.8t convertions are getting more popular, and lots of questions being asks as to whats needed)
josh
Offline danmusic24
« Reply #5 on: 30 November 2011, 07:54 »
What about rad,can you use 8v one or do you have to use twin fan 16v  :smiley:
Offline F17BAD
« Reply #6 on: 30 November 2011, 08:51 »
You can just use the 8v GTI item
I used twin rad fan as the 16v car I used for some parts had one but it's not essential
I'll add it to the optional list tho all the same :wink:
Offline VR6_Wherry
« Reply #7 on: 30 November 2011, 08:54 »
HERO!
I will add this to my FAQ thread :)
Cheers!
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 30 November 2011, 15:07 »
DEFO STICKY!!!!!!! :wink:
I was going to ask someone to do this as its getting asked alot of times.
so good going kells
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
« Reply #9 on: 30 November 2011, 17:10 »
 :kiss:  :grin:
I'm gonna do this I think.
but I have just bought a gillard rotax chassis so the car will have to wait  :lipsrsealed:
