Merchandise shop
Model specific
Golf mk6
TDI
(Moderators:
Agreeable Slick
Mr GTD
Bio Fuel - Diesel
Topic: Bio Fuel - Diesel (Read 1234 times)
ajmoir36
Bio Fuel - Diesel
13 November 2011, 20:51 »
Right I was filling up at Morrisons the other day and I noticed on the pump it states that there is up to 7% bio-fuel in the diesel. Now on the fuel flap it has a No Bio-Fuel sticker.?? Is all diesel like this ? Surely not good for the Golf?
Diagonally parked in a parallel universe.
Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio + DAB, Cruise, Winter Pack, Luxury Pack and Tyre Pressure Sensors. Vagcom'd up (now bluetoothed and Rear LED's).
GTD Gearbox Whirr
GTD Miles Per Gallon
p3asa
Re: Bio Fuel - Diesel
13 November 2011, 21:57 »
Esso has 8% in its diesel
I asked the same question here
http://www.golfgtiforum.co.uk/index.php?topic=200523.msg1867841#msg1867841
and the consensus was it would be fine.
dieseldunc
GTI forum regular
14 November 2011, 07:13 »
I think it's an EU Directive (Law?) thing, in that all diesel has to have a small % of bio in it. It only becomes called 'Bio Fuel Diesel' at a higher % and it's that that VW are saying stay away from.
Someone can prob elaborate / find actual details - this from my early morning memory
sssh; it's 'only a diesel'; but i love it!
MK6 GT140 TDi; DBP; Vancouvers; RNS510-D; Convenience pack; Storage pack; Philips Extreme Vision dipped bulbs; blue vision sidelights; red footwell lights; Yeti tips; GTD pedals; GTD gear lever; 'R' mats; RVC; Premium Bluetooth and some TLC.
Agreeable Slick
Global Moderator
Serious forum addict
Professional advocate of oil burners
14 November 2011, 09:20 »
As above.
All injection systems are now designed to cope with up to ~15% "biodiesel" from standard with fittings like viton etc to resist the corrosive properties of the "bio" parts of the mixture.
I made this : ->
ajmoir36
14 November 2011, 22:56 »
What about performance? better or worse with bio-fuel any ideas?
GTD Gearbox Whirr
TJD
The quality remains after the cost is forgotten.
30 November 2011, 20:48 »
I was reading my manual
whilst waiting for the lovely wife yesterday and came across this :
"Caution - Your vehicle is not suitable for use with biodiesel and must not be filled up or driven with biodiesel. If you use biodiesel fuel, the engine and fuel system could be damaged. Some diesel manufacturers blend biodiesel with diesel fuel in compliance with European Standard 590.
This diesel is suitable for use in your vehicle and will not damage the engine and fuel system
tips & maintenance book P38
As a result was curious!
The web says -
http://www.biofuelsforum.com/using_biodiesel/4425-what_exactly_en_590_a.html
EN590 (actually EN590:2000) describes the physical properties that all diesel fuel must meet if it is to be sold in the EU, Czech Republic, Iceland, Norway or Switzerland. It allows the blending of up to 5% Biodiesel with 'normal' DERV - a 95/5 mix. In some countries such as France, all diesel sold routinely contains this 95/5 mix.
Wikipedia says -
http://en.wikipedia.org/wiki/EN_590
EN590 describes the physical properties that all automotive diesel fuel must meet if it is to be sold in the European Union, Croatia, Iceland, Norway and Switzerland.
It allows the blending of up to 7% fatty acid methyl ester with 'conventional' diesel - a 93/7 mix.
I will be checking the diesel spec at my local pump next time!
Hope this helps
MK6 GT140. Reflex silver. Vancouvers.
ajmoir36
Reply #6 on:
30 November 2011, 22:18 »
I think texaco uses the british standard which doesn't contain biofuel
GTD Gearbox Whirr
Model specific
Golf mk6
TDI
(Moderators:
Agreeable Slick
Mr GTD
Bio Fuel - Diesel
