Author Topic: boot wont open any way to get in  (Read 1347 times)
Offline gti genty
« on: 18 October 2011, 08:38 »
aup lads as above boot wont open on car i can hear it actuating in the lock when i press the central locking but nowt there on the handle just wondered if there was any levers to pull or owt cheers gti genty
if in doubt go flat out
Offline Mr_Orange
Re: boot wont open any way to get in
« Reply #1 on: 18 October 2011, 08:47 »
Do a search.  You can release it manually:
http://www.golfgtiforum.co.uk/index.php?topic=140307.0
Seems quite a common problem; the lock is likely ruined from a leaky wiper unit, or hopefully the release rod may have come off the solenoid.
Build thread clicky
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #2 on: 18 October 2011, 09:31 »
Mine went the other month.... heres how i fixed it....
Tried getting in the boot and removing the trim which was a pain so i opened the key slot slightly with a screw driver and blasted loads of WD40 in there and worked the key in and out, after a while of locking/unlocking the car it finally worked.
Once opened i removed the trim and gave it a good covering with the good old WD40 and not had a problem since
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
