Author Topic: k03 / k04 wheel size list  (Read 30439 times)
jamie16v
Re: k04-023 turbine and compressor size
« Reply #10 on: 17 October 2011, 20:44 »
then use a silicone bend and a metal connector tube to connect the hybrid inlet to my modified silicone tip, that way no new boost
had thought about it, but would prefere to avoid it.
i`m unsure exaclty what the benefits of the 360 deg bearings are, i just know theyre better. thats good enough for me until i find the time to read up one it :wink: i would also take into consideration, it may be worth sending the newly built core off for high speed balancing before you put the housings on and use it.
« Last Edit: 17 October 2011, 20:49 by jamie16v »
jamie16v
« Reply #11 on: 17 October 2011, 21:29 »
@ wolverine _ souldnt be much, but gives you peace of mind...
heres an interesting read, though when he mentions the k03s turbine housing, i think he actually means k04-001.
http://forums.vwvortex.com/showthread.php?1598145-285-HP-Ibiza-FR-Turbo-is-in...
jamie16v
« Reply #12 on: 19 October 2011, 15:11 »
found more info here on vortex.. http://forums.vwvortex.com/showthread.php?3516484/page3 cant see much for turbine though
KO3
5303-123-2018
Inducer diameter: 33.63mm
Tip height: 3.71
Exducer diameter: 46.02
5304-123-2201
Inducer diameter: 38.48mm
Tip height: 4.67
Exducer diameter: 50.95
5303-123-2011
Inducer diameter: 31.45mm
Tip height: 3.12
Exducer diameter: 44.96
5304-123-2007
Inducer diameter: 36.02mm
Tip height: 3.89
Exducer diameter: 49.96
and for the KO4:
5304-123-2029
Inducer diameter: 37.95mm
Tip height: 4.39
Exducer diameter:50.95
5304-123-5010
Inducer diameter:34.90mm
Tip height: 3.61
5304-123-2032
Inducer diameter: 34.54mm
Tip height: 3.28
5304-123-2202
Inducer diameter: 37.74mm
Tip height: 4.42
5304-123-2023
Inducer diameter: 36.65mm
Tip height: 4.04
5304-123-2018
Inducer diameter: 35.97mm
Tip height: 3.68
5304-123-2007
Tip height: 3.89
5304-123-2000
- see above under KO3 section
5304-123-2005
Inducer diameter: 34.90mm
Tip height: 3.73
Offline littco
« Reply #13 on: 19 October 2011, 15:42 »
The A/R ratio is the ratio between the cross-sectional area (A) of the turbine scroll at any one point and the distance or radius (R) from that point to the center of the turbine-wheel. This ratio is always constant so each point along the turbine scroll will have the same A/R ratio. A turbo with a smaller A/R ratio will tend to create more torque while a turbo with a larger A/R ratio will provide more power because more exhaust gas energy will be acting on the turbine-wheel. Generally, an A/R ratio of 0.7 will provide better low-end response, while an A/R ratio of 1.4 will provide more top-end power.
Basically a ko3s compressor housing will give more torque and less bhp but in fairness in you're not going to really loose that much .
jamie16v
jamie16v
« Reply #15 on: 19 October 2011, 21:28 »
would be easier to bolt the k04 onto the k03, not sure the gains would be great though...  :undecided:
jamie16v
« Reply #16 on: 20 October 2011, 10:16 »
true, but i dont think it would be alot more over the k03s.
jamie16v
« Reply #17 on: 20 October 2011, 12:22 »
lol, thats not what i meant.. i meant i dont think a k03/k04 hybrid would give much gain over the k03s. the k04 bolted on would give alot more top end power but less low end torque. so, would be less drivable as a daily.. i had thought about it but for what its worth and the route i am planning i think full k04 internals in the k03s housings would be a better bet. if i could get my hands on the k04-001 for peanuts then i would hyrbrid that but its not going to happen..lol
Offline Dave_IOW
« Reply #18 on: 20 October 2011, 19:42 »
If i could get my hands on the k04-001 for peanuts then i would hyrbrid that but its not going to happen..lol
Keep your eyes open bud, happened for me  :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
« Reply #19 on: 20 October 2011, 19:50 »
it`s more money than i got mate to be honest.. when i say peanuts i mean like £20 at the most.. im just going to stick with the bits i have got now and make something out of them.. :smiley:
