Author Topic: 1.8 turbo conversion  (Read 14761 times)
Offline stainesy
« on: 13 October 2011, 20:52 »
I'm seriously thinking about doing a 1.8 turbo conversion but have never done a conversion before. What do I need to do the conversion?
I mean like what parts do I need in total?
Offline Dan_GTi8v
Re: 1.8 turbo conversion
« Reply #1 on: 13 October 2011, 20:57 »
I'll try and dig up my shopping list when I did mine
Offline Dan_GTi8v
« Reply #2 on: 13 October 2011, 21:03 »
this is just my list, I'll look over it in a bit as I'm in the middle of cooking dinner atm  :grin: Obviously some things are up to you and the code can be any transverse 1.8t (as opposed to longitudinal fitted ones like those in the U.S)
*Cable to hydro clutch parts (master cylinder, slave cylinder, and fluid lines)
*Engine and Gearbox brackets
*Engine and Gearbox mounts
*Engine AUM
*Gearbox 02a
*Intercooler
*Boost pipes
*VR Clutch
*ABF Flywheel
*Downpipe from QPeng (ask Kells about his though, same price and better quality)
*Sports cat (for no messing about at MOT)
*MK4 PAS Pulley
*SAI block off plate
*Forge TIP
*Forge 007 recirculating diverter valve
*modified loom (give rubjonny a pm or I think topher knows someone who can do it as well)
*ECU immob defeated and 2nd lambda mapped out (Topher did this for me along with a stage 1 map)
*16v starter motor
I'll add to it as I remember anything else :)
There will be many things you forget about or wont know you need until you come to it. I started from an 8v GTi, ideally you wanna start with a 16v as a lot of the work will be done for you.
what are you starting with? anything under a GTi would need other stuff as well such as bigger brakes etc
« Last Edit: 13 October 2011, 21:09 by Dan_GTi8v »
Offline stainesy
« Reply #3 on: 13 October 2011, 21:42 »
I will be starting with my 8v gti. Have been thinking about more power for a wile.
Debating weather to buy a VR6 and transfer all my mods over to it or to do a conversion to mine.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #5 on: 14 October 2011, 10:51 »
http://www.golfgtiforum.co.uk/index.php?topic=124485.0 :afro:
That thread is pretty useless really
You will need more than above too, new engine mounts and a exhaust with a 2.5" bore like jetex are a must.
It's no cheap game. The VR6 route would be easiest and cheapest
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline stainesy
« Reply #6 on: 14 October 2011, 11:39 »
Yeah but it's just the fuel cost after though.
Offline Dan_GTi8v
« Reply #7 on: 14 October 2011, 11:52 »
Anyone can go out and buy a VR6 :P
I'd say its worth doing the conversion not only because it will be a 1.8t! but doing it yourself you learn a lot about the engine and how it works, with my 8v it was always a bit of guess work and forum searching trying to find solutions to problems, but now I can say I know what 99% of the stuff under by bonnet does, where all the pipes go, if I do get a problem I know what the likely causes are and how to fix them :)
One tip I'll give toy if you do decide to go for it is plan to spend over your budget  :grin:
« Reply #8 on: 14 October 2011, 12:47 »
Worth remembering a 1.8t remapped is not that much better on fuel.  :smiley:
Offline Dan_GTi8v
« Reply #9 on: 14 October 2011, 15:18 »
mine on a stage 1 is about the same as my 8v gti but I also have a pretty bad boost leak somewhere that needs sorting.
ATM I'm trying to find a local vagcom so I can check my fuel trims, probably end up buying one though as I can see myself needing it quite a few times to see if its getting any better. If you do the conversion adding vagcom to the list of parts needed would be a good idea  :laugh:
