GolfGTI.co.uk forum
Model specific
Golf mk3
mk3 maintenance + info
GTI cutting out, oil light flashes
Username:
1 Hour
1 Day
1 Week
1 Month
Forever
Password:
Quick Search
Advanced Search
[Close]
Calendar
4
5
38
Topic: GTI cutting out, oil light flashes (Read 46439 times)
Scott
Offline
Re:GTI cutting out, oil light flashes
Reply #20 on:
December 15, 2003, 10:03 »
Replaced relay No. 30 in the end, and thought all was fine until this morning - cut out for split second on way into work. Nutsacs!!!
Looks like I will have to start messing around with the VW immobiliser - anyone know where there are any handy wires I could cut to immobilise the immobiliser???
If that doesn't work I may have to replace the Hall Sender (and thus the whole god damn dizzy!), a nice ?200 bill for that I beleive.
Mk4 PD150, Jazz Blue, nice! Puts my old Mk3 Gti to shame
golfvr6
Guest
Reply #21 on:
December 15, 2003, 10:54 »
You should be able to just replace the hall sender.
Scott
Offline
Reply #22 on:
December 15, 2003, 10:58 »
Really? I was told that it was not removable on the mk3 Gti and that I have to buy a whole new dizzy - or were they telling me porky pies?
I have not seen any hall sender units sold seperately for the mk3 either, not on GSF or ECP anyway. Do you know of where I could get one, would it be easy to fit?
Mk3 1.8 CL
Just got here
Offline
Reply #23 on:
December 15, 2003, 12:10 »
Please help.
The cutting out loss of power problem is all over forums and very few have fixed it.
This relay sounds very promising as my golf has exactly the same problems described by so many.
I wanted to know if this only applied to those of you with GTI's
I have heard of other standard mk3's with the same problem but don't know if this Hall sensor Relay will fix mine?
please help as i'm running short of time!
Thanks Mk3 1.8 CL
8vgti
Here all the time
Offline
Reply #24 on:
December 15, 2003, 13:44 »
Quote from: Scott on December 15, 2003, 10:58
Scott, have a look at the earlier responses to this post, probably page 1 or 2, where I posted the VW part number for the Hall sender. I had this problem on my 8v and got the part (well VW diagnosed and fitted part) from VW for only ?13. Worth a try for the money.
Scott
Offline
Reply #25 on:
December 17, 2003, 10:26 »
8vgti - that is the part No. for
Relay No. 30
; I know because I went & got one from VW last week, and as mentioned - did not cure the cutting out. Thanks for trying to help anyway. By the way, I only paid ?9.69 + VAT for mine! (Vindis VW, Milton Rd, Cambridge).
If anyone has had JUST the hall sender replaced and NOT the whole distriutor could they possibly post a part No. on here? I am running out of (cheap) ideas, I really don't want to have to replace the whole dizzy, the moths in my wallet need some peace!
8vgti
Here all the time
Offline
Reply #26 on:
December 17, 2003, 13:36 »
Sorry Scott my mistake, when I read my earlier post (page 2) I actually misinterpreted it!! On VW service sheet it said..."no readings recorded at hall sender...so replaced ECU power supply"...not as you say replaced hall sender. Surprising that the price of relay 30 can vary between dealers especially on such a low priced item. Let us know how you get on as would be interested to know.
jaseb
Just got here
Offline
Reply #27 on:
December 17, 2003, 18:27 »
Scott I'm in the Cambridge area and after reading through this post I went to VW Vindis, St.Ives got the ECU relay for a tenner plugged it in this morning and no change
I'm having the engine stalling after about fifteen minutes from cold I replaced the fuel pump relay three weeks ago that stopped it for two weeks but then it started up last week, I've tried cleaning the throttle butterfly out, changing the ECU relay this morning I don't know what else to do, I think I'm going to replace the fuel pump relay agian see if it stops it again.
The thing is I even rang round a couple of VW dealers in the Cambridge/Peterbourgh area and they all said the same thing that it was the fuel pump relay.
If anyones got any other ideas I'd appreciate them.
golfvr6
Guest
Reply #28 on:
December 17, 2003, 19:18 »
Have you changed anything else? or just the relays?
jaseb
Just got here
Offline
Reply #29 on:
December 17, 2003, 19:46 »
Just the two relays and the ignition bit where your key goes in (don't know the right name for it) thats what the garage said it might be when I took it in. They were wrong however so I haven't taken it back.
Is this a common problem only on MK3 GTi 8v's or does other MK3's have this problem??
4
5
38
Jump to:
Please select a destination:
=> Chat - VW related
===> Dub rides
===> Photography
=> Chat - new forum members
=> Dub projects
===> mk1 projects
===> mk2 projects
===> mk3 projects
===> mk4 projects
===> mk5 projects
===> other dub family projects
=> Site news & bright ideas
=> Shows, events & meets
===> Events planning
===> Regional meetings
=> Track days and motorsport
=> Car audio
=> Cosmetic matters
===> Virtual modifications
=> Detailing
===> Detailing guides and faq
=> The garage
===> Diagnostics - vagcom
=> Remapping (ECU tuning)
===> R-Tech
=> Insurance
=> The good guys
Model specific
=> Golf mk1
===> mk1 maintenance + info
=> Golf mk2
===> mk2 maintenance + info
=> Golf mk3
===> mk3 maintenance + info
=> Golf mk4
===> TDI
===> mk4 maintenance + info
=> Golf mk5
===> mk5 maintenance + info
=> Golf mk6
===> mk6 maintenance + info
Classifieds and more
=> Classifieds
===> Alloys and tyres
===> Audio and nav parts
===> Brakes and suspension parts
===> Breaking for spares
===> Cars for sale
===> Engine and exhaust parts
===> Exterior bodywork, trim and lighting
===> Interior parts
===> Other car parts for sale
===> Wanted
Loading...
