Author Topic: temp sensor query  (Read 480 times)
Offline stevelfc
temp sensor query
« on: 17 September 2011, 18:11 »
changed ny temp sensor on a golf 1.8t AGU about 2 months ago with a genuie part green one and every time i have checked my car for faults it come up with
Temp sensor  (SPORADIC )  and when i earse fault and check again a week later it comes up with same fault any ideas
« Last Edit: 17 September 2011, 18:21 by stevelfc »
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: temp sensor query
« Reply #1 on: 17 September 2011, 18:56 »
How are you erasing the fault though?
You need to go into the individual module controller and do it that way, not just the 'clear codes' button when you read them all.
Offline stevelfc
« Reply #2 on: 18 September 2011, 09:21 »
yes m8 as i am using a Bosch kt200 and when you read faults you can earse them after and when i check fault gone but if i check a week later fault come back
« Reply #3 on: 18 September 2011, 10:35 »
Maybe the sender is faulty  :undecided:
