Author Topic: yellow spring any one  (Read 2570 times)
Offline dam088888
« on: 15 September 2011, 20:51 »
Had map today has any one got a yellow spring for dv as I have standard one and am I right in thinking a yellow one will hold boost longer. So if any one has one they font use any more and fancy selling me it would be good
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline GTI.T
Re: yellow spring any one
« Reply #1 on: 15 September 2011, 21:00 »
I aint got a spring but i dunno wether you got an email from me regarding your oil pick up pipe was it any good
Offline dam088888
« Reply #2 on: 15 September 2011, 21:11 »
Yes mate thanks had a look at your post and was discribed well thanks
Offline GTI.T
« Reply #3 on: 15 September 2011, 21:19 »
the sealent ya need is called dirko proper goes of quick and do on the inside edge of the bolt holes not the outside or you gonna get someone to do it for ya?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 15 September 2011, 21:20 »
stronger spring won't let you hold boost for longer it will just stop the DV cracking open with the extra boost being put through the system
Offline dam088888
« Reply #5 on: 15 September 2011, 21:35 »
I'm gonna do it quit handy with the spanners lol you end up with any leaks from sump
Offline dam088888
« Reply #6 on: 15 September 2011, 21:36 »
So wazzer is it worth swapping for a yellow or not
Offline GTI.T
« Reply #7 on: 15 September 2011, 21:38 »
I got the smallest of drips not that im gonna worry will just watch it
Offline dom
  • Back in a Mk4
« Reply #8 on: 15 September 2011, 21:51 »
If mapped then yes.
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #9 on: 15 September 2011, 21:59 »
If mapped then yes.
+1
