Author Topic: Ken's '87 golf GTI 8v restoration  (Read 97818 times)
Offline Ice_ken
Re: Ken's '87 golf GTI 8v restauration
« Reply #10 on: 28 August 2011, 20:30 »
before:
after:
few things more:
rad done:
fan done:
« Last Edit: 28 August 2011, 21:09 by Ice_ken »
Offline Ice_ken
« Reply #11 on: 28 August 2011, 20:32 »
windscreen washer bottle, OEM pump:
K-jetronic:
some more:
« Last Edit: 28 August 2011, 21:07 by Ice_ken »
Offline Ice_ken
« Reply #12 on: 28 August 2011, 20:37 »
before:
after:
few things done, oil cooler i'm probably not going to use:
fuell-lines:
« Last Edit: 28 August 2011, 21:00 by Ice_ken »
Offline Ice_ken
« Reply #13 on: 28 August 2011, 20:47 »
distribution cover:
sump:
inside:
windage tray:
some stuff from the stealer:
bought some rims:
that's about it for now, i'm still working on it every day for the next month.
« Last Edit: 28 August 2011, 21:03 by Ice_ken »
« Reply #14 on: 28 August 2011, 21:02 »
Looks a great project :afro:
Offline DubFan
« Reply #15 on: 29 August 2011, 12:50 »
Woa!
That's gonna be like new. You've cleaned all those parts? How'd you get them so clean ?
Offline DanChave
« Reply #16 on: 29 August 2011, 16:54 »
Excellent work so far man! Sooo clean  :smiley:
Offline Ice_ken
« Reply #17 on: 29 August 2011, 19:02 »
Woa!
wire brushing, degreaser, painting, polishing, etc did everything myself so far.
Offline Ice_ken
« Reply #18 on: 29 August 2011, 20:53 »
well
-the old trans is off my engine
-the head is also off
-so is the oilpomp, clutch, engine mounts, startermotor and that plate between the engine and trans.
engine:
cylinder 1: fine
cylinder 2: bit of a score in the wall, my nail catches on it
cylinder 3: fine
cylinder 4: piston is a bit lighter of color(think the injector is probably f*cked), rest is fine
head:
fine, exept for 2 brokes studs for the exhaust, 1 of them is inside the cylinderhead.
clutch was on the edge of being worn, so I need a new one, this one was a sachs
Offline Ice_ken
« Reply #19 on: 30 August 2011, 16:17 »
still the first original startermotor:
engine and stuff:
not good:
pistons, looking good:
cylinderhead:
