Author Topic: Stage 2 preparations..  (Read 12889 times)
Offline golf-sib
  • Турботазик
Re: Stage 2 preparations..
« Reply #20 on: 22 March 2011, 19:54 »
Pretty sure the AGU injectors on full cycle at 4bar can easily cope with 260bhp... Any reason why you are interested in an intank pump?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline jamie16v
  • MK4 AGU 1.8t
« Reply #21 on: 22 March 2011, 20:04 »
just replace the pump if weak and fuel filter. personally i would stick the LCR pump on anyway red injectors are probably overkill but will flow better. i assume that they will have to be fitted on the day so allow more time, if you fit them before you will probably risk running a bit rich.
AGU ecu loom connector wanted
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 22 March 2011, 20:28 »
AGU injectors run 258cc injectors, so 440s are nearly doubling it lol
Offline golf-sib
  • Турботазик
« Reply #23 on: 22 March 2011, 20:33 »
Wouldn't upping it to 4bar increase flow rate though making them more than applicable for a 260bhp setup?
1.8T AGU..
R135
  24
Offline houston
« Reply #24 on: 22 March 2011, 20:41 »
why not just fit an inline pump?
Offline Dave_IOW
« Reply #25 on: 22 March 2011, 21:33 »
have looked at them but undecided if want anything else in the engine bay..
i only ask about injectors/pump as thats what Nick hinted at, if unneccesary i will sell and put funds towards remap.
just thought they may be a limiting factor..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 22 March 2011, 21:44 »
in line pump will be easy enough to rig up
Offline Dave_IOW
« Reply #27 on: 22 March 2011, 21:49 »
if tank one is tired though, possibility at 90k, how will that effect inline one?
How exactly does it work? I take it one in tank stays there?
Offline houston
« Reply #28 on: 22 March 2011, 21:53 »
it takes the load off the tank pump so less chance of it failing, just plugs onto the line, easy to fit
Offline rockmonkey69
« Reply #29 on: 22 March 2011, 21:55 »
The old fuel pump becomes effectively the fuel pick-up and doesn't do the pumping, the in-line pump takes over
