Author Topic: coolant and turbo hose diagrams  (Read 18342 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: coolant and turbo hose diagrams
« Reply #10 on: 17 February 2011, 21:49 »
Yup sorted on the 5 piece now m8 nice one for the pics.so bumper off and light out for intercooler to throttle body then.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 17 February 2011, 22:30 »
how come you've got a wheel bolt where that dangling breather should be?
Offline daz veedub
  • Operation 1.8t bolf
« Reply #12 on: 19 February 2011, 13:03 »
r-tech did that so not sure, gona put breather back on
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 19 February 2011, 17:45 »
looks like the boost line in to the pcv valve has been capped off too, you'll want to get the right pipe and attach that back to the manifold while you're at it or you'll be pulling vapours through the turbo.
Offline daz veedub
« Reply #14 on: 19 February 2011, 17:52 »
see what u mean what pipe do a need and where on manifold did it go  cheers
Offline topher
  • Administrator
  • fully functioning
« Reply #15 on: 19 February 2011, 18:03 »
its a thin Z shaped piece, connects to the underside of the inlet manifold near the dipstick (you'll find it blocked off somehow). Part number for AGUs is 06A103221C. If it's been done like that because the bleeder valve inside the t-piece is broken then the part number for the valve is 035103245A
Offline daz veedub
« Reply #16 on: 19 February 2011, 19:16 »
is it not just 1 pipe i need....which t-piece u mean mate
Offline daz veedub
« Reply #17 on: 19 February 2011, 19:18 »
ill have a more in depth look 2moro, then get on 2 vw for said part no.s thanks again mate
Offline daz veedub
« Reply #18 on: 20 February 2011, 11:24 »
see what ya mean now topher nice 1 do u know y they would of blocked em of as never said owt 2 me
Offline topher
  • Administrator
  • fully functioning
« Reply #19 on: 20 February 2011, 12:55 »
dunno mate, but looking at your other picture it was like before the new TIP was fitted.
