Author Topic: HOW TO: Change lights in dials/MFA displays & adding extra LED's - Pic Heavy  (Read 47480 times)
Offline itavaltalainen
which leds have you bought (part number)?
the clocks in the link are mk3 clocks aren't they? which bulbs do you wanna replace, just clocks or the ones for lcds?
there are no 12V LEDs... LEDs have forward voltage of around 1.5 ~3V depending on type, so for replacing dial ones you will need resistors... if that is just buy a few different ones (would suggest 5 different values across) from e.g. maplins between 680 and 1k5 or 2k ohms.
09/2016 Golf VII GTD DSG 50k miles
Gone: 11/2013 Golf VII Variant GT 2.0 TDI pacific blue - 123k miles
DASH SWAPS and KEYS LEARNING for most VWs up to MY2005 even if you don't have the PIN - FAULT CODES - ADAPTATIONS -  Windows via remote fob for Golf 4 and other 2000s VAGs -OXON and the whole country
Offline sharki786
  • GOT BOOST??
Your wrong there. I have 3mm 12v leds. But for the display (smd) you could get the mk4 clocks strip them down and get the smds out of them. Also go to rs componants for the leds waaaaaayyy cheaper then maplins.
*****MK3 Anniversary*****
*****MK4 GTI T*****
I repeat there are no 12V leds, so suspect what you got is a LED with a current limiting resistor built in which is overall rated for 12V ;)
e.g:
http://pdf1.alldatasheet.com/datasheet-pdf/view/221008/BRIGHT/BR-B21V1-12V.html
Offline sharki786
  • GOT BOOST??
e.g:
Well i got 3mm red led in the drivers windows switch which doesnt have a resistor. So you must be right.
*****MK4 GTI T*****
Offline samehalabhar
