Author Topic: HOW-TO 020 & 02A Gearbox guide [Alignment and rebuild]  (Read 29564 times)
Offline Khare
  • The bear that khares
« Last Edit: 07 February 2012, 20:23 by boneybradley »
Offline dom
  • Back in a Mk4
Re: 02A Gearbox guide [Alignment and rebuild]
« Reply #1 on: 01 February 2011, 20:34 »
http://www.vwmotorsport.com/vwtech/gears/mt_02A_overhaul.pdf
Excellent guide here!
Great guide! I need to adjust my linkage so that is perfect.
Offline Khare
« Reply #2 on: 01 February 2011, 20:43 »
You've got 020 though dude  :undecided:
Just found this in the corrado forum too.
Quote
As regards the gear selection problem, first port of call is the cable end to gear box attachment. It's poor engineering design as the nut is only tightened to 10 ft lb and has no lock nut or other retainer mechanism. It can work loose as consequence.
Need two peeps, get someone to move the gear stick across the gear gates from 5th to reverse ie. the neutral right to left movement, without engaging any gears. On the gearbox you will see only one cable move the gearbox controls. The cable throws the lever back and forth over a short arc. Put the gear stick fully over to the reverse gate but not forward into the reverse gear position. While it is held there, see if the cable end/gearbox lever control will go further towards the that end of travel. If it does, then the cable end fitting has slipped. A crude way to adjust the cable end/gearbox lever control is to slacken the nut slightly. Hold the cable end and push the lever so that the end travel coincides with the gear stick's full travel across the gate at either end of the across left/right neutral throw. At the extreme ends of the cable movement, there is hardly any play and if there is it should be a balanced at each end of the cable's travel. When happy with the set-up, nip the nut upto 10 ft lb, Any more and damage may occur to the plastic end fitting on the gearchange cable. May be worth taking the nut off and putting some "lock-thread"on the threads of the cable attachment.
If this is not it, then there is a problem inside the gearbox.
Offline dom
  • Back in a Mk4
« Reply #3 on: 01 February 2011, 21:58 »
Just realised that  :rolleyes: :grin:
Offline Khare
« Reply #4 on: 01 February 2011, 22:00 »
 :kiss: :kiss: :kiss:
Offline Khare
« Reply #5 on: 01 February 2011, 22:59 »
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #6 on: 03 February 2011, 18:45 »
Good find Khare, me and Kells are doing a full re-build ofthe 02a going in his conversion so this will help  :wink:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #7 on: 03 February 2011, 18:56 »
yeah big up Khare - cheers man :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Khare
« Reply #8 on: 03 February 2011, 19:01 »
Seems a good guide! Glad its helped you guys out :afro:
Offline F17BAD
« Reply #9 on: 03 February 2011, 19:05 »
it certainy will do mate, great guide, many thanks  :wink:
