Author Topic: Error Code P1296  (Read 17673 times)
Offline simonparsons
Error Code P1296
« on: 28 December 2010, 09:42 »
Hi guys,
I have a Mk4 GTi (1.8T) on an 02 plate, which has started coming up with a fault code recently. The fault code is P1296, which seems to be a fuel air metering issue (I have also seen other sites mention the code relating to the cooling system, but i dont think they are for VWs)
I havent noticed any issues with the fuel economy or performance, but have recently noticed that when pulling off in second gear, it seems a little jittery as if not enough fuel is going through. No issues in other gears, and if you push the accelerator a little harder it seems ok, but just not quite right. We have another 1.8T and that doesnt have any similar issues.
i presume both are related, but thought i would see if anyone else has had this issue and what they did to sort it out.
many thanks in advance for any help
Si
Offline AaronGS
Re: Error Code P1296
« Reply #1 on: 28 December 2010, 10:40 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 December 2010, 10:53 »
Offline richw911
« Reply #3 on: 28 December 2010, 11:54 »
Welcome  :cool:
As said temp sender  :smiley:
See here:
http://www.golfgtiforum.co.uk/index.php?topic=88088.0
« Reply #4 on: 28 December 2010, 11:59 »
gooooooooooooooogle
http://www.cars-guide.com/volkswagen-forum/engine-code-mystery-solved-code-p1296-t1944.html
temperature sender by the look of it
Thanks for the prompt replies. I did take a look on google, but there seem to be a selection of different results, which is why i wasnt entirely sure, and thought i would ask the question.
From the link that you have sent, it refers to changing a temperature sensor, but looking in the haynes manual, it refers to two temperature sensors - a coolant temp sensor and an inlet air temp sensor. would i be right in assuming the former is the one in question here?
as a seperate thought - any idea why a lot of other sites reference an air metering issue
i will check out some of the links and go from there
thanks guys for all your help
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 28 December 2010, 12:37 »
coolant sensor fault will play havoc with the fuelling hence the metering issue :wink:
Coolant sensor is on the right hand side of the engine (looking from the front)
Offline richw911
« Reply #6 on: 28 December 2010, 12:38 »
gooooooooooooooogle
Check out the link i posted above  :wink:
« Reply #7 on: 09 January 2011, 19:36 »
Many thanks for all the advice guys.
Finally got the part delivered in the week and its a nice quick fit. touch wood it has all been on thus far, but i will update the post again should the issue come back in quick succession
Highly recommended for anyone who has similar issues, as the replacement part was about £15 from euro car parts. Just be aware there are two different colours (blue and green) so make sure you check the right one first
Offline richw911
« Reply #8 on: 09 January 2011, 19:56 »
Which was all in the link i posted  :wink:
« Reply #9 on: 16 January 2011, 15:39 »
hi guys.
all had been well for about a week, but the error code appears to have returned. any other ideas?
Si
