Author Topic: what wire does what.  (Read 8414 times)
Offline mcgee9t2
« on: 26 December 2010, 21:33 »
okk, received a dvd head unit for xmas, the conector for it just has the wires coming off though to be atached streight to the standard wires, now does anyone have a wiring diagram for the standard conection block? or know which wires go to left front/back speeker, right front/back speekers ect.
in around 20 mins i will list each and every wire i need to connect. cheers
Offline mcgee9t2
Re: what wire does what.
« Reply #1 on: 27 December 2010, 13:15 »
ok little update
the wires i need to connect to the existing wires are
+12v constant
ground
reverse camera +12v (not got a reverse camera so leave unconected?)
power antenna/amplifier remote
rear left +
rear left -
rear right +
rear right -
front left +
front left -
front right +
front right -
+12v switched
parking break
cheers for any info guys
Offline dragonfly
« Reply #2 on: 27 December 2010, 14:35 »
Have a look at the wires on the rear and front speakers - that'll sort them out, leaving the power and earth which I think is red and brown.  Attach the parking brake to the earth - you will be able to watch a DVD whilst moving.  HOWEVER this is illegal so make up your own mind on this. The proper way to connect it to the handbrake.
Offline mcgee9t2
« Reply #3 on: 27 December 2010, 14:51 »
yeah i was hoping someone would know the colours cause im not feeling my best today and cant be botherd to chase wires around the car :D but suposse ill have to take the door cards off and have a look at each wire colour. as for the parking break, im not gonna be watching dvds while driving so just need to make it so i can watch dvds when sat in car waiting for someone or something.
so sofar we have
Quote
+12v constant red?
ground brown?
reverse camera +12v (not got a reverse camera so leave unconected?) left unconnected?
power antenna/amplifier remote ?
rear left + look in the door for colour
rear left - look in the door for colour
rear right + look in the door for colour
rear right - look in the door for colour
front left + look in the door for colour
front left - look in the door for colour
front right + look in the door for colour
front right - look in the door for colour
+12v switched ?
parking break atatch to earth
Offline mcgee9t2
« Reply #4 on: 27 December 2010, 14:55 »
iirc the red/yellow wire is switched? is this the same as 12v switched?
Offline LowlifeDubber
« Reply #5 on: 28 December 2010, 07:41 »
Look at the iso plug on your car and just match the pin number to the wire colour. :wink:
2000 Volkswagen Golf Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
Offline mcgee9t2
« Reply #6 on: 28 December 2010, 10:43 »
lowlife, you are a legend. cheers for that.
quick question. my car is 1999 which colours do i use then as you  stated 2000 which im guessing is from 2000 onwards and then in the table its pre 1998?
cheers
« Last Edit: 28 December 2010, 11:39 by mcgee9t2 »
