Author Topic: Miles to empty on a VDO immo 3 cluster using Vagtacho  (Read 27730 times)
Offline old_n07
« on: 24 December 2010, 19:19 »
It is about time I wrote this I think  :smiley:
Let's get this bit out of the way, you perform this mod at your own risk, if you screw your cluster up don't blame me! Only do this if you are confident you know what you are doing  :nerd:
Miles to empty on a VDO immobiliser 3 cluster. If you don't know which cluster you have then take a look at the cluster FAQ here :afro:
To use this guide you will need:
1.                   An immobiliser 3 VDO cluster
2.                   Vagtacho software and cable (VT)
3.                   A Hex editor, I am using XVI32 available here
1. Connect up your cable to the laptop and car then with the ignition on run the Vagtacho software (VT)
2. If you know which cluster you have then you can skip this part and go to 3
Press Connect Any Tacho
VT will return the cluster info and from the part number and type you can tell if your cluster is VDO and immo 2 or 3 :afro:
Then click the disconnect button
3. Select VDO new from the ECU drop down list
And click on connect selected ECU
VT will connect and return the following info
4. Reading the SKC code (PIN number)
                Press the read PIN button
The SKC is returned by VT, to use in VCDS (Vagcom) put a 0 in front ie 03957
5. Reading the cluster eprom
Press the Read button in VT
When done File > Save
Save two copies of the file, one labelled original and one modified!!!
6. Editing the eprom
Close VT and open up the HEX editor XVI32 and File > open
Open the file you saved with the modified label :afro:
To enable miles to empty the hex address $416 needs to be modified, in a standard cluster the value will be C1, to turn on MTE change the value to E1
Click on Address > Goto
Enter $416 in the box and make sure hexadecimal is selected > OK
This will highlight the address value in the eprom file
Click on the address value and type in E1, the blue selection will then move to the right and select the next value but don’t change this value.
If you make a mistake re load your file into the editor and start again :afro:
To enable lit pointers the value at address $1ED need to be modified, in your standard cluster it will be 30, the value is changed to 3X where x represents the value in the list below:
x value
3              - displays only
5              - gauges only
7              - displays and gauges only
9              - needles only
B              - displays and needles only
D             - Needles and Gauges only
F              - all lit up
39 is the most common choice but feel free to experiment :afro:
Enter $1ED in the box and make sure hexadecimal is selected > OK
Click on the address value and type in 3x, the blue selection will then move to the right and select the next value but don’t change this value.
Once you have finished editing File > Save
Close the editor
7. Uploading the modified eprom to the cluster
Open up VT again and connect to the cluster as in steps 1 and 3 above
Click on File > Read file >
select your saved modified eprom dump and this will be loaded into the VT memory buffer
Click on write eprom
Click on continue and VT will write the eprom back to the cluster
Wait until Done
Click on options > Reset Tacho
And that is it, disconnect your cables :afro:
If you have any issues with the eprom write then you can try to put the original file you saved back onto the cluster, this is not always possible however and the cluster could end up dead :cry:
Hope that makes sense
Neil
« Last Edit: 06 August 2012, 19:49 by old_n07 »
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline old_n07
Enable the Welcome message on a full FIS cluster
« Reply #1 on: 24 December 2010, 19:20 »
Using the above methods change the value at $417, in a cluster without the Welcome message it will be 02, change the value to 6B to enable the message
This only works on a Full FIS VDO immo 3 cluster :afro:
Neil
Offline richw911
Re: Miles to empty on a VDO immo 3 cluster using Vagtacho
« Reply #2 on: 24 December 2010, 19:24 »
Top stuff from the original clock master Neil :afro:
Offline old_n07
« Reply #3 on: 24 December 2010, 19:27 »
There are a lot of people buying the copy cables off ebay Rich, I just don't want someone to screw their cluster up by not knowing what they are doing
Offline richw911
« Reply #4 on: 24 December 2010, 19:29 »
Indeed awesome thread really helpful  :cool: :cool:
jamie16v
« Reply #5 on: 24 December 2010, 21:10 »
good guide neil, i would say its spot on.. i did this myself with help from yourself and others on ukmkivs.
i used a clock set from a passat but its all the same, the only difference is i had to upload a dump file from an anni to make it all work. the soft codings and everything had to be changed to get it spot on too.  :smiley:
Offline mikemk4gti
« Reply #6 on: 29 January 2011, 16:02 »
Just done this to mine, excellent guide!
Thanks Neil, you're a genius!
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline vxr
« Reply #7 on: 20 November 2011, 18:47 »
Thanks for the writeup, used vag tacho to turn in the mte and needles on my tdi anniversary today and all worked well.
HOWEVER! my rev counter now doesnt work :cry:, used VAG COM to test the instruments and everything works fine, then used the live readings on VAG COM to check siginal and all is ok here shows idle at 880rpm. I tried writing eeprom back to my saved orginal but still no rev counter.
Has anyone got any ideas where I may have gone wrong??
Thanks
Paul
