Author Topic: update on brake fault now code 01435  (Read 5173 times)
Offline vw-8v
« on: 27 November 2010, 23:24 »
right i had master cylinder donewith mot all in 298 thought great it fixed lol oh no it aint this morning  got the same beeping noise when i started up and reversed  :sick: :angry: so put fault reader in on the off chance there was a code as last time no codes were found.
code 01435 came up (thanks again adam this code reader of fleebay saving me more money) sochecked ross tech and . . . . .
01435 - Brake Pressure Sensor 1 (G201)
01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Basic Setting not performed
Possible Solutions
Perform Basic Setting
01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
Brake Pedal Switch (F) faulty/jammed
Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
Check/Replace Brake Pedal Switch (F)
See Measuring Blocks
Check/Replace Brake Pressure Sensor 1 (G201)
ABS Hydraulic Unit (N55) may need to replaced
Perform Brake Pump Bleeding
Perform Brake Pressure Sensor 1 (G201) Basic Setting
Replace Brake Electronics Control Module (J104)
i read a topic by mk5 owners and am i right thinking if i get a new abs unit an this will stop the crappy preasure in the pedal and beeping??????
Offline vw-8v
Re: update on brake fault now code 01435
« Reply #1 on: 29 November 2010, 15:09 »
just called vw and it 1500 quid for the part lol f***k that there not much left on this car that aint bloody new so gonna source second hand part.
does anyone know answer my original post that this is the right corse of action to take tyo wipe out fault code and pedal presure??????????????????????????????????????????????????????????????????????///
Offline vwprime
« Reply #2 on: 29 November 2010, 15:14 »
How do the brakes fill? Are thay stoping and all that?
TRANSFORM, & ROLL OUT!
Offline vw-8v
« Reply #3 on: 29 November 2010, 16:58 »
i put on my fault reader at the start of prob.
any time i started car put into reverse or 1st moved ten feet out of parking space applyed brake to select gear and flash od hand brake on warning light and 3 beeps then pump pedal couple times move off and all is good for all of journey 2 miles or 200 miles.
i've had full brake system check for leaks, buldging or age related probs = all good all greased total clean = still same prob next morning.
then put fault reader on again no faults, so vw specialists advised brake master cylinder. . . .  so 300 quid later (with mot)new master cylinder next morning same sh*t.
on off chance put on fault reader agian and fault 01435 hence copy of first post after checking on ross tech
now pedal response excelant once over first prob very good and should b for the money.
vw quoting 1500 for pump as guessing this is the prob, found one on ebay for 140 ish what u think ? and how mych to do job at garage?
cheers
