Golf mk4
Wazzzer
Clamping the MAP sensor??
Topic: Clamping the MAP sensor?? (Read 4249 times)
Big Tone
31 October 2010, 19:56 »
Anyone tried this?
http://forums.vwvortex.com/showthread.php?1484504
Seems a bit "rough ar*e" for me.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install, New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Clamping the MAP sensor??
31 October 2010, 20:14 »
its simple yet very clever.. i would pay for someone to do it not attempt it myself im crap at electrics lol
Mk4 Golf GTI anniversary and mk6 golf tdi
Big Tone
31 October 2010, 20:20 »
Do you not think that tricking the ecu into thinking that the boost is different than it actually is will mean that you run the risk of causing engine damage?
tech1889
Mk2 GTI FTW !!
31 October 2010, 20:23 »
No read the link in the link that you provided it explains all the stuff that it does.. It is like a boost controller.. stock... 11psi.. 17psi.. it would work..
Big Tone
31 October 2010, 20:33 »
I did read the link, thought I understood it, you "clamp" the boost at a level just before going into limp mode no?
Thought a MBC was also a no-no on a 1.8t?
tech1889
Mk2 GTI FTW !!
31 October 2010, 20:47 »
A boost controller is a no no but you are doing it in a different way to which a boost controller works..
yes so if you clamp the sensor and fool the ecu you dont go into limp mode.. problem solved..
Big Tone
Reply #6 on:
31 October 2010, 20:59 »
What values would you use for a mapped car?
Also, take it you would need a mbc for this?
tech1889
Mk2 GTI FTW !!
Reply #7 on:
31 October 2010, 21:02 »
mbc ?? manual boost controller ??
You cant run a boost controller on a 1.8t at all whether mapped or not because of it being a recirc turbo.. will cause issues..
Im not sure on a mapped car to be honest..
Big Tone
Reply #8 on:
31 October 2010, 21:10 »
I don't understand, how can you increase the boost otherwise?
tech1889
Mk2 GTI FTW !!
Reply #9 on:
31 October 2010, 21:18 »
your not increasing the boost your clamping it at a certain psi.. im lost..
Golf mk4
Wazzzer
