Author Topic: XENONS - Q & A retrofitting & functionality  (Read 211599 times)
Offline latta1989
Re: XENONS - Q & A retrofitting & functionality
« Reply #630 on: 01 May 2012, 18:26 »
This is the latest info I have, I think it came from RossTech
1K0-937-084 (Basic - Supports NO Fogs or Xenons)
1K0-937-085 (Low - Supports NO Fogs or Xenons)
1K0-937-086 (Medium - Supports Fogs but NO Xenons)
1K0-937-087 (High - Supports Fogs and/or Xenons)
Although it says 084 doesn't support Fogs, not sure whether that is front or back.
Thanks!
Probably front because my car didn't come with front fogs.
What difference do the letters make after the part number?
Golf Mk6 1.6 TDI Match Bluemotion Tech
Offline mike.
« Reply #631 on: 01 May 2012, 18:48 »
This is where things get a bit more complicated as it seems to depend on what options are fitted to the car.
This is where my knowledge runs out and I relied on SteveP to get the part number for the BCM I needed.
From what I can see you need 1K0 937 087 R XXX
The XXX is the bit I don't know and depends on the options, could be ZOB, ZOC, ZOD, ZOE etc..
Mine was ZOK..
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline latta1989
« Reply #632 on: 01 May 2012, 19:31 »
Mine was ZOK..
Did you not say your part no. was 1K0 937 087 E ?
Why do u reckon mine would be R?
Hope SteveP could maybe help me out on this then. I have no PM yet unfortunately.
Offline mike.
« Reply #633 on: 01 May 2012, 19:43 »
Mine was a 2010 car, from your number it looks like a 2011 car so the revision number cross references on ETKA to R
You should be able to PM now you have more than 10 posts  :laugh:
Offline latta1989
« Reply #634 on: 01 May 2012, 20:56 »
Kl cheers. Ye it's 2011 car.
Woohoo go me.  :smug:
I'll try pm him see if he can post in here incase his answers help other folk too.
Offline Mr GTD
« Reply #635 on: 30 August 2012, 17:34 »
Just got a reply from my local dealer regarding parts for the retrofit... :shocked: :sick: :shocked: :sick:
Headlight Units...
1x Left Headlight...5K2941753D - £448.64 inc.VAT
1x Right Headlight...5K2941754D - £448.64 inc.VAT
2x Xenon Retaining rings...5M0941645 - £7.69 Each inc. VAT
*2x AFS Power module...7L6941329B - £168.74 Each inc. VAT
2x Xenon Ballast...5M0907391 – £181.07 Each inc.VAT
2x Xenon Bulb(D1S)...N10566103 - £154.43 Each inc. VAT
10x Srews....N10708601 – 49p each inc. VAT
*1x Kufatec Xenon adapter...36849 – Will have to order through Kufatec
AFS and Self Leveller (Only rear required for none ACC)
1x Self Leveller...1K0941273L – £121.44 inc. VAT
5x Screws...N10430103 – 26p each inc.VAT
5x Nuts...N10597701 – 53p each inc.VAT
1x Grommet....6N0906102 - £2.36 inc. VAT
*1x Kufatec Loom (for non ACC)...37139 – will have to order through Kufatec
1x AFS Controller...5M0907357C (H04, SW142) – £148.99 inc.VAT
BCM Controller
1x BCM...1K0937087EZ0K –  £287.53 inc. VAT (currently Back order)
All of the above parts will need to be ordered in with a expected delivery time of two working days (except the BCM controller),
These are non returnable parts so payment will be needed before ordering.
Total £2490.31 :sick: :shocked:
Offline abh100
« Reply #636 on: 04 September 2012, 21:34 »
I was just wondering - was just looking at this kit:
http://www.carsystems.pl/xenon-dynamic-headlights-with-drl-golf-6-r20-5k941753e-5k1941754,id298.html
And it kinda made me wonder - I thought there was some kind of EU requirement that if you have Xenons they need to be kept properly free of dirt and so it's necessary to have an ability to clean them - i.e. with the headlight washers.
If I don't have the winter pack/headlight washers, would it likely fail an MOT does anyone know (when it becomes due!)?
Mk6 GTi, 5dr, Manual, '61, Black, Leather, Ross-Tech VCDS MicroCAN/USB, RCD510+BT
Offline Johnny937
« Reply #637 on: 26 October 2012, 15:16 »
Does anyone know the correct coding for clearing main beam left/right bulb out warnings on dash?
This is for retro fitted xenons which where orginally halogen headlights.
 I changed byte 17 bit 2 which is (xenons fitted high beam not active) and this clears the codes but high beams dont work.
Read else where that using the bit editor in vcds can change byte 17 but need some info as i cant find the bit editor on vcds?
any help would be much appreciated
