Author Topic: HOW TO: Install BMC CDA Induction Kit - VR6  (Read 4603 times)
Offline VR6_Wherry
« on: 20 August 2010, 11:10 »
Thought i would do a write up as i had trouble with this.
The BMC CDA Kit comes as a universal kit, which means it isn't a direct fittement. (Which confused me as i didn't realise it!)
1. Remove Old airbox. I unclipped the top half, then wriggled the bottom half out. then gave it a quick clean of any debris.
2. Hose connection. Due to it being universal, you need to join the Kit with a hose. I got an 83mm hose from here: http://siliconhoses.com/content.asp?inc=product&catalog=0022C&cat=0022C connect this to the engine side of the Kit, like so:
3. Connect it back up. Then connect the hose back up, tighten the jubilee clips and your good to go.
Here is mine all connected up:
You get a better sound if you don't use the cold airfeed i've been told.
« Last Edit: 21 August 2010, 00:18 by boneybradley »
Offline Jimp
Re: How to: Install BMC CDA Induction Kit - VR6
« Reply #1 on: 20 August 2010, 18:38 »
Good write up :afro: This will be very useful for anyone who hasn't installed this kind of thing before :afro:
Not low enough mk5
Not on the road enough mk3
