Author Topic: Anything else worthwhile coding with VAG.com on a MkVI?  (Read 69662 times)
Offline p3asa
Re: Anything else worthwhile coding with VAG.com on a MkVI?
« Reply #70 on: 22 December 2010, 22:08 »
It allows the RNS510 that I had just installed to work with the camera.
Offline Snoopy
  • Moderator
  • 28+ years of GTI ownership.
« Reply #71 on: 30 December 2010, 11:19 »
Anyone found anything else worth doing?  :undecided:
Mk1 GTI, Mk6 GTI, Mk1 Leon & 4 non VW.
Offline The Doc
  • M2 DCT / 335d Xdrive / Vito Sport
« Reply #72 on: 30 December 2010, 17:34 »
I've killed the rear wiper auto wipe on reverse, coded the front fogs to act as cornering lights and front fogs as coming / leaving home lights.
Tried to do the pass mirror dipping in reverse and even got the option in the dis but it didn't work  :sad:
Offline Rhyso
« Reply #73 on: 30 December 2010, 18:06 »
Can you tell me where you do that? I've looked right throughout the CE module but it doesn't work on the Audi  :undecided:  Not sure if my module supports it
What options did you tick?
Ta  :smiley:
Offline Snoopy
  • Moderator
« Reply #74 on: 30 December 2010, 18:09 »
Fogs as coming/leaving home.
Im sure i noticed it in the long code helper. :undecided:
Im not sure if it works without the lux pack mirrors.
iirc you have to have the switch set to the left mirror. Set into reverse, set the mirror were you want it with reverse activated. so it knows were to dip to. Something like that.
Would be great if we could get it to work without the lux pack mirrors though.
« Last Edit: 30 December 2010, 18:14 by Snoopy »
Offline Rhyso
« Reply #75 on: 30 December 2010, 18:12 »
That's where I've looked  :sad: :undecided:
Offline Snoopy
  • Moderator
« Reply #76 on: 30 December 2010, 20:02 »
Byte 17 bit3
Just took a look.
I did an autoscan while i was there i have an error  :cry:
Offline The Doc
« Reply #77 on: 30 December 2010, 20:04 »
It seems you need extra wiring into the pass door mirror etc  :sad:
Offline Rhyso
« Reply #78 on: 31 December 2010, 10:42 »
Byte 17 bit3
Just took a look.
 :sad:
Audi is different.  Never mind.  Thanks for looking  :smiley:
Offline 182_blue
« Reply #79 on: 13 January 2011, 09:47 »
Does the speed only come up when driving ?, mine doesnt display speed ?
Cheers p3eps, great find. Its got rid of the pesky KMH in the dash. Just hope I don't take the car abroad now  :laugh:
I'll post a photo of mine tomorrow - but mine fills the full display with MASSIVE numbers!!
