Author Topic: Anything else worthwhile coding with VAG.com on a MkVI?  (Read 75119 times)
Offline p3asa
I've got a loan of a VAG.COM cable so need to return it and wondered if there was anything worthwhile I should code while I still have the lead?
What I've done so far is:
Rear view camera re-coded
Buttons on MFSW
Nav directions on MFD (awesome feature)
Audio now back on MFD
Alarm chirp when locking doors
Changed colour of RNS510
Emergency brake warning (although couldn't get it to work no matter how hard I slammed the brakes on. Maybe not a UK setting?)
Auto Closing Windows via Rain Light Sensor
Voice control (although not installed the mic yet)
Got rid of KPH and have the temperature there instead
Have a large digital MPH in the MFD
« Last Edit: 27 February 2012, 12:02 by p3asa »
Offline VWKev
  • Please Support Non-Human Rights
Re: Anything else worthwhile coding with VAG.com on a MkVI?
« Reply #1 on: 14 May 2010, 22:26 »
what about the dials spinning round on start up, I cant remember its name.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline sundaydriver
« Reply #2 on: 14 May 2010, 22:29 »
Dial staging
VCDS Version 912 beta
Select under 17 Instruments - 10 adaption - Staging and activate.
according to vortex seems to only work only on GTI's built on or after 12/09
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline VWKev
« Reply #3 on: 14 May 2010, 22:32 »
Dial staging
Thats the name, dial staging. thanks.
Is that right about the date ? I'm sure I've seen a video of it working on someones GTI on youtube and that was before 12/09.
Offline Ess_Three
« Reply #4 on: 14 May 2010, 22:40 »
If the Inst Cluster is the 'D' revision, it'll work.
I set mine last week.
Also: close sunroof from keyfob/rain sensor
Memory function of drivers heated seat activated.
..but gaining motorcycles.
Offline Ess_Three
« Reply #5 on: 14 May 2010, 22:41 »
Buttons on MFSW
What's this all about then?
Offline p3asa
« Reply #6 on: 14 May 2010, 22:54 »
Buttons on MFSW
The buttons had stopped working since I upgraded to the RNS510 that's all.
Staging didn't work for me but then I don't have a GTI. It seems to be a bit hit and miss whether it works or not according to this thread
Offline p3eps
« Reply #7 on: 14 May 2010, 22:54 »
When you first fit an RNS510 without coding it, it sometimes doesn't work with the steering wheel.
p3asa - one thing I coded that is really useful is change your settings to Rest Of World - and then you can have a HUGE digital speedo in the MFD!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline Snoopy
  • Moderator
  • 29+ years of GTI ownership.
Current Stable: Mk1 GTI, Mk6 GTI, Mk1 Leon & 3 non VW.
Offline Ess_Three
« Reply #9 on: 14 May 2010, 22:57 »
Really?
Where is that setting found?
I'll be having a bit of that..
Do you scroll into it as a menu option on the MFD?
