Author Topic: Oil Temp/Oil Pressure sensor fitting.  (Read 4220 times)
Offline johnson6672
« on: 08 May 2010, 14:02 »
After some advice on fitting sensors for oil pressure/oil temp gauges.
will i need a oil filter sandwich plate connect the sensors for the gauges or is there somewhere else to connect?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Purely VAG
Re: Oil Temp/Oil Pressure sensor fitting.
« Reply #1 on: 08 May 2010, 14:40 »
You can go straight into the original oil pressure port - Have to remove your OEM one though
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline johnson6672
« Reply #2 on: 08 May 2010, 15:09 »
Can you fit both of the sensors in that area?? Been looking at some bits and pieces and found that there is meant to be 2 threaded drillings on the filter mount or is it a case of getting an adaptor with more thatn one hole and doing it that way as i would guess the car would have probelms if you disconnected the OEM sender.
The gauges are the ones that you sold to MK1macca Jordy
kcolevol
« Reply #3 on: 08 May 2010, 15:16 »
I got both these gauges running. Had to buy a sandwich plate and run them from there.
Offline johnson6672
« Reply #4 on: 08 May 2010, 15:17 »
Where from and how much?
kcolevol
« Reply #5 on: 08 May 2010, 15:26 »
Pretty sure the 5th one down is what i got but depends on the size of the fitments to your gauges that your paperwork should tell you mate.
https://www.burtonpower.com/product_main.aspx?dets_product.aspx?PSet=97&sTxt=sandwich
Offline johnson6672
« Reply #6 on: 08 May 2010, 15:38 »
http://cgi.ebay.co.uk/SANDWICH-PLATE-OIL-PRESSURE-TEMP-GAUGE-BLUE-/270568224724?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3eff1f77d4
http://cgi.ebay.co.uk/T-PIECE-OIL-PRESSURE-TEMP-SENSOR-SENDER-Bracket-/370366079078?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563b89e066
Not sure which of these to go for  :undecided:
Does anyone know the thread of the standard drillings by the oil filter, i'm sure i read somewhere that they are m10x1, as most of the stuff i have found so far has been 1/8 NPT
Offline johnson6672
« Reply #7 on: 08 May 2010, 18:52 »
Anyone got any answers for above.
Offline Purely VAG
« Reply #8 on: 08 May 2010, 21:03 »
For the price difference, id use the sandwhich plate.
Offline johnson6672
« Reply #9 on: 09 May 2010, 08:03 »
Cheers Jordy, i was thinking that, i guess not many people are running oil pressure/temp gauges then :shocked:
