Author Topic: List of phones for Rsap VW premium inside  (Read 19095 times)
Offline SteveP
Re: List of phones for Rsap VW premium inside
« Reply #10 on: 20 April 2010, 22:39 »
^^^ Then a VW 729C or D is what you want.
There seems to be a new E version also, do you know if that works to ?
Also, if you dont have a BT kit from the start, are the wires there so you can install one or do you need to install all the wireing also ?
Thanks
/I
Yes the E version works too (that's the version I have in mine now).
If your car wasn't pre-wired for bluetooth then a plug and play harness is required, most of the main sellers of the kits include this  :smiley:
Offline am1w
« Reply #11 on: 20 April 2010, 22:43 »
Are you satisfied with the VW Premium kit?
Which phone do you use?
Hope you don't mind me asking. :smiley:
BMW F30 330d M Sport in Superman colours
Offline SteveP
« Reply #12 on: 20 April 2010, 22:48 »
^^^ I removed the factory Premium rSAP Kit (part number 730) and replaced it with the 729 Standard Bluetooth (with uses the much more widely supported Hands Free Profile).
I use this kit a Blackberry 8310 (work phone) or iPhone 3GS.
Have also successfully tried a couple of HTC's, the Blackberry Storm, Pearl and Bold plus a few Nokia's like the 5200, N95, N97.
Offline am1w
« Reply #13 on: 20 April 2010, 22:56 »
That's good news.
I was getting into a bit of state about all this.
Darren will probably order the 729 Standard Bluetooth kit.
I'll suggest this to him tomorrow.
Thanks for your help.
Your knowledge is invaluable. :smiley:
Offline isse
  • Golf R
« Reply #14 on: 21 April 2010, 20:58 »
So then you need to fit these cables from under the passanger seat all the way to the RNS510 unit ?
Removing panels, trim etc...sounds a bit tricky...has anyone done it ?
Also since i have a voice control Navi i was hoping to be able to re-use that Mic for the BT handsfree also...
/I
« Last Edit: 21 April 2010, 21:00 by isse »
Offline SteveP
« Reply #15 on: 21 April 2010, 21:03 »
^^^ It's easy enough to build in the VC for the RNS with the OEM bluetooth, the pins for the mic in and mic out are labeled on the connector B on the back on the RNS.
It takes me around 30mins to remove the trm panels to be able to install the bluetooth kit  :smiley:
Offline mortygt140
« Reply #16 on: 22 April 2010, 15:50 »
Steve most of the new BT looms come with VC already pre wired so no need for extra wires now :cool:
Takes about 30 mins has Steve said I think Daves Scirocco took me less but some of the trim isn't screwed in so it just pulls off and on.
Darren
Offline isse
  • Golf R
« Reply #17 on: 22 April 2010, 20:39 »
New BT kit on the way, at least for the US market, and probably for retrofit.
http://askavwsalesguy.com/2010/04/21/rejoice-new-bluetooth-is-coming/
Offline mortygt140
« Reply #18 on: 22 April 2010, 21:19 »
Already available but not sure if it will intergrate with the RNS like the premium,  the part number is 7P6 035 730C and its the 9W7 package. I bet its a basic low module and doesn't show details on the RNS??
Darren
Offline am1w
« Reply #19 on: 22 April 2010, 21:26 »
Darren
Thanks :smiley:
AM
