Good Lord!!
Today it was MOT time for the mk2 VR6.
to summarise: 17 failures, 18 advisories, alarm went haywire during the experience and now it runs rough as ....!!!
Most of the failures are simple things like brake pipes not securely fitted, rear pads worn, rear wheel bearing noisey etc. The rear axles mounts are sh*gged though! And these were only done a year ago. But it would explain why the car wanders all over the road at the moment!
The alarm stopped operating the central locking from the point at which i parked it up this morning, first time thats happened. Then it kept going off when the car was being MOT'd! but since ive got it home its back to normal!
Failed on emissions (CO 0.5% too high), perhaps that can be adjusted on the VR6, but on the drive home the engine started running rough as **** under load. Keeps dying on you when you accelerate, splutters like mad. plus idle is no longer steady. Lift pump isnt priming though and under body pump is very noisy so i suspect a faulty lift pump. The pump connector gets power.
Anyone know which lift pumps can be used? obviously the digi mk2 one can, but how about a mk3 one?
