Author Topic: INFO: HIDs - An Insight  (Read 10264 times)
Offline Matty-MK3
  • Automatic boats FTW.
« on: 13 March 2010, 18:45 »
Seeing how every week there is an argument discussion about HIDs I thought I'd gather everyone's thoughts up on them.
HIDs are High Intensity Discharge lights. Instead of a filament they work by igniting gas in between two points that have around 1100V running through them. They are extremely bright and 35W is enough, 55W is a bit much really.
First off, are they legal?
No. Not on a MK3 Golf. Not on stock lights, Hella Twins or any aftermarket lights alone. To be legal they need HID approved projectors or reflectors, be auto-leveling (although auto-leveling suspension is fine and also the dipped beam must stay on with the high beam. They also need a headlight washing system.
However, many people run them without problems. Providing the beam pattern is OK, they get through MOTs. However, in stock lights they DO glare. Members on this site claim they have driven past their car with them on and have not been affected by the glare, however. They have also said they have been around traffic cops and VOSA vehicles and been stopped and the car checked and have been fine.
However, as long  as you are aware that they are illegal, you run them at your own risk, which, if you are sensible with them, is fairly low TBH.
Kelvin rating. You will see loads of kits on eBay and the like with a XXXXK rating. This is depth of colour. 3000K is yellow, 4300K is crystal white, and what most manufacturers use in their cars as stock, although some use 6000K. 6000K is a very white colour with a hint of blue at some angles, it looks very "modern". 8000K has a fairly blue tinge and is just about the limit if you don't want any attention for them. 10000K and above has quite a colourful tinge to them and kind of defeats the object as it gets duller.
High beams. HIDs are not recommended in high beams as if you flick them to flash someone or want instant high beam in country lanes etc they don't work properly. Saying that, a brand new Audi flashed me with HID high beams the other day (they have high beams HID as stock as a cutoff moves) and it wasn't bright at all and just showed up a dim blue glow in his headlights.
They aren't difficult to install, you need to connect your existing bulb connectors to the ballast that comes in the kit then the ballast to the bulb. It will come with fitting instructions and really isn't hard. You will want to make sure the back of the headlights is sealed though to stop water and dirt getting in.
When you switch them on they explode with brightness then go dim and warm up, this is normal, it takes about 30 seconds to be at full brightness, they are also very blue for the first few seconds.
Shady Pioneer, the moderator of this section, emailed his insurance company and they classed it as a modification with no trouble. This is recommended as it doesn't give them much room in the event of an accident.
If you have Dayglo where the dipped beam comes on dimly with the sidelights, it is recommended you remove it. This is because if you put your sidelights on the HIDs flicker then go out, then when it gets darker and you flick the dipped beam on they don't work. You have to turn it right off then right back on again. Also, mine used to flicker permanently if I had been using them then went back to sidelights.
So in summary, they aren't legal, but as I said, be sensible and the risk is very low. Keep them aligned and it'll go through an MOT. They are very handy in driving at night as as Joe said "you can see further then the front of your bonnet".
« Last Edit: 21 August 2010, 00:28 by boneybradley »
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline javalin
Re: HIDs - an insight
« Reply #1 on: 13 March 2010, 19:05 »
good information.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Adam
« Reply #2 on: 13 March 2010, 19:24 »
Bulb K(elvin)-
Bulb Fitments-
Down Hill From Here.
Offline VR6-Joe
« Reply #3 on: 13 March 2010, 19:44 »
8000k is for pimps.
That is all I have to add to this topic.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Matty-MK3
« Reply #4 on: 13 March 2010, 19:56 »
I thought that was 12000K. :grin:
Offline VR6-Joe
« Reply #5 on: 13 March 2010, 20:43 »
No, they're for w@nkers :cool:
« Reply #6 on: 13 March 2010, 21:44 »
Very good info :afro:
Quote from: Diamond Hell
You suck at buying cars, please take the pointy D hat from Wayne and go sit in the corner.
Offline Shady Pioneer
  • graphic designer.
« Reply #7 on: 14 March 2010, 13:53 »
Very good info and just because it's a hot topic I'm going to sticky it. :afro:
Offline Matty-MK3
Re: HIDs - An Insight (What you need to know)
« Reply #8 on: 15 March 2010, 23:17 »
This is what you remove to remove the dip-dim resistor. (Thanks VR6-Joe):
  • graphic designer.
« Reply #9 on: 16 March 2010, 00:21 »
I don't have one of those. :huh:
