Author Topic: possible flat battery, help please :)  (Read 1639 times)
Offline bmw156
« on: 11 March 2010, 17:17 »
hey guys, been driving my gofl for a few days now, and i love it.
but today twice i have gone to turn it on, and it is as if i have left my lights on (which i havent) so i try again and its fine and starts fine, runs fine.
any idea why it would fail to start and then start fine?
possible alternator on its way out? battery on its way out?
i think ill get a multi meter on the battery and see if its drawing any current with the ignition off. lol
Offline naturn007
Re: possible flat battery, help please :)
« Reply #1 on: 11 March 2010, 17:21 »
When you say "it's like the lights have been left on" are you saying it tries to start, or is there nothing?
It maybe the ignition switch.
Offline bmw156
« Reply #2 on: 11 March 2010, 17:31 »
it does the common "struggle to turn over"
so i turn the key back to turn it off, try again and it fires up fine, loose wire do you think?
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #3 on: 11 March 2010, 18:10 »
Check your battery terminals for tightness, it could be a starter issue also.
Offline jonnypolish
  • t2871r needed :)
« Reply #4 on: 11 March 2010, 19:34 »
You don't happen to have a hefty amp in there do you?
 MK2 VR y0!
Offline christomk3gti
« Reply #5 on: 11 March 2010, 20:25 »
an amp should not drain the power anyway as they are powered up via the head unit, but if the amp is faulty it could be draining the power from the battery when engine is off.
I run a big amp in mine and never have issues... touch wood :afro:
Black 8v GTI............. Whats a Waffle Valve?
Offline bmw156
« Reply #6 on: 11 March 2010, 20:31 »
no i dont have a heafty amp lol, im not a hom.
im gonna check all the connections in the engine bay, to the battery and starter.
« Reply #7 on: 11 March 2010, 20:34 »
good start..
then check the alternator. This can cause the battery to drain when the engine is off if its goosed.
Offline VR6-Joe
« Reply #8 on: 11 March 2010, 20:36 »
Get on msn!!!!!!!!!!!!!!!!!!!
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline bmw156
« Reply #9 on: 11 March 2010, 20:54 »
im not at homeeeee
