Author Topic: One for the experts, air bag warning ligh and fault codes!  (Read 9279 times)
Offline tonyg
First of all i'm pretty new here so Hello all!
Right, i'm in need of some expert advice and any help is much appreciated.
The problem is with my 01 Golf 1.8 Gti T 5 door that i bought yesterday. The air bag light is on and it has obviously had a bump at the front upper passenger side.
It was the right price so i bought it regardless.
It's showing 8 codes in total and none of them will delete, they are:
0253 Crash data stored faulty
04BE Air bag control unit crash data stored belt tensioner
024C Drivers side front air bag, ignitor circuit 1, highly resistive
024D Passenger side front air bag, ignitor circuit 1, highly restive
028F Belt tensioner ignition circuit passenger side front highly resistive
028E Belt tensioner ignition circuit driver side front of low impedence
0214 Power supply signal too low
0513 Gateway blocked power failure
The error codes would not delete and i realise after reading the error codes it sounds bad but the car looks and drives extremely well.
So has anybody got any advice on where to start with this please?
Offline snap-on
Re: One for the experts, air bag warning ligh and fault codes!
« Reply #1 on: 22 October 2009, 23:13 »
sounds like the seat belt tensioners have fired and also the airbags too ? have the airbags been replaced etc ? any history of cat d/c etc
you can get the crash history removed from the log by sending unit off for clearing as not possible with a scanner , i have a number if you need it .
Offline navmk4gti
« Reply #2 on: 23 October 2009, 00:32 »
clear the codes... and see which ones come back.. if airbags been replaced and your seat belts are working fine then its just matter of clearing em... check the airbag plug's aswell..may just not been put on propely
i had a bump on mine and both seat belts siezed up.. so had get new belts (they come with tensioners on em) and cleared codes ..then airbag light went off  :wink:
Offline tonyg
« Reply #3 on: 23 October 2009, 11:18 »
Cheers for the quick response!
I hpi'd the car and it clear and it's obvious just by looking under the bonnet that it wasn't a big bump.
I didn't realise the crash data couldn't be deleted via the scanner so thanks for that snap-on can you give me the number please to get the unit wiped?
If the airbags had fired then they've been replaced the interior looks and is fitted as good as factory, so maybe its had a new dash and steering wheel.
Like navmk4gti says, maybe i need to get new seat belts and then clear the codes and go from there.
Where is the airbag ecu?
I will let you know how i get on!
Cheers guys very helpful!
« Last Edit: 23 October 2009, 11:22 by tonyg »
Offline jonnyturbo
« Reply #4 on: 23 October 2009, 11:26 »
No experts here mate lol
Offline navmk4gti
« Reply #5 on: 23 October 2009, 16:48 »
did you clear codes on your vag com mate?? if you did see which ones have come back and then go from there.. no point changing stuff that may not need changing  :wink:
Offline richw911
« Reply #6 on: 23 October 2009, 18:44 »
As said you cant remove the crash codes with a scanner  :wink:
Offline tonyg
« Reply #7 on: 23 October 2009, 19:05 »
Yeah i tried to remove them with vagcom but they wouldn't delete, it wasn't until i started this thread that i learnt you need a specialist to remove them.
After a quick search on google i found this company;
 http://www.northernautotech.co.uk/airbag.html
Has anybody used these before?
Offline old_n07
« Reply #8 on: 23 October 2009, 19:12 »
They can also be cleared if you know anyone with Vag K+ Commander it has a reset crash data function :wink:
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline snap-on
« Reply #9 on: 23 October 2009, 19:51 »
thats a good price £45 so worth doing it with them ! you also need to find out if the belt tensioners have fired and not been replaced etc , you might even have a faulty unit which is showing all these codes or maybe if the car had i light impact where a wiring loom travels and it got damaged and repaired or damaged and never found !
if the bags go off its just a case of replacing them which is easy for anyone to do but you then need to get the crash data removed from the unit . thats why scanners wont remove the data for safety reasons etc as you could buy a car thats had a wack change the bits , clear the codes and sell on quick so the next person has a wack a nothing happens etc etc .
have a good look to see if or where its had an impact and have a good look around as bodywork and trims hide a lot of stuff .
have you checked all airbag fuses etc ?
