Author Topic: Rear Door Help Needed  (Read 1862 times)
Offline THiNK
  • Golf MK4 GT TDI 150
« on: 20 September 2009, 18:07 »
My rear passenger door has the childlock for obvious reasons  :wink:
Today i hit the remote to let the little one in and it didn't open, hit the lock but and open button a few times and nothing. All other doors and boot were fine each button press.
I tried with the key and also using the drivers door button controls and still nothing.
The window still works with the button on the door and with the key and drivers door button.
As I can not open the rear door I cold do with any help or comments you may have :)
Thanks,
CS
Offline bobreece
Re: Rear Door Help Needed
« Reply #1 on: 20 September 2009, 18:26 »
happend to me other day on the passenger drivers side door turned out it had come of the trigger dont know how it happened was fix in 5min my local vw mechanic
Offline Rhyso
« Reply #2 on: 20 September 2009, 19:55 »
does the little lock pin pop up or does it stay down?
if it pops up as said its possible the cable has come unattached
if it stays down it sounds like a faulty door module
Offline THiNK
« Reply #3 on: 21 September 2009, 08:50 »
Stays down and when you pull the handle inside it pops up a little but you can not grab it to force it up or anything.
If it is the door module how the hell do you open the door to take the panel off to replace it?
Thanks,
CS
Offline Rhyso
« Reply #4 on: 21 September 2009, 08:59 »
sounds silly but give the area around the lock pin a good thump
the solder inside the door module seperates - a good thump might just be enough for it to make contact again and open the door
Trouble is you kind of have to repair it there and then!
Do you have VAGCOM to confirm if it is a door module?
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« Reply #5 on: 21 September 2009, 13:49 »
I had this issue this time last year, If your is a 5 dr mk4 then you simply get in through the other side and take the door card off to replace the module,
Offline Rhyso
« Reply #6 on: 21 September 2009, 13:54 »
can you get at the screws at the bottom with the door shut though?  :huh:
Offline THiNK
« Reply #7 on: 21 September 2009, 15:55 »
Got a Vag Com demo i'll run later.
I do like the thumb to work option though !!
CS
Offline THiNK
« Reply #8 on: 22 September 2009, 08:18 »
OK the punching the door didn't work.
Any other tips to get the door open?
Cheers,
CS
Offline THiNK
« Reply #9 on: 23 September 2009, 11:24 »
Looks like I might have to book it in :(
Any ideas on cost?
Thanks,
CS
