Author Topic: i want to service my Golf Gti 16v.....myself!!!  (Read 2365 times)
Offline *Dickie*
« on: 18 August 2009, 14:57 »
Hello
i needs sum help as i want to service my 95 N Golf Gti 16v myself but i dont know wot i need to change ie spark plugs, air filter but im not sure wot else i need to do.
can any1 help me please?
Offline Adam
Re: i want to service my Golf Gti 16v.....myself!!!
« Reply #1 on: 18 August 2009, 15:00 »
Change-
  • Oil filter
  • Oil
  • Spark plugs
  • Air filter
Then if your feeling it-
  • Replace dizzy
  • Fuel filter
  • HT leads
Down Hill From Here.
Offline Horney
« Reply #2 on: 18 August 2009, 15:03 »
Check:
Suspension bushes
Disc and pad thickness
Nick
gtigolfthree
« Reply #3 on: 18 August 2009, 15:06 »
and pollen filter.
Offline MK3GTI_16Valve
« Reply #4 on: 18 August 2009, 15:07 »
Whats the mileage of the car? What does the service history say? Is it due a timing belt......Bit more detail and I'm sure you'll get the info you need. If your just planning a basic service then follow the advice above
adamrob69
« Reply #5 on: 18 August 2009, 15:10 »
>plugs
>oil
>oil filter
>air filter
you may want to do..
>coolant
>pollen filter
>fuel filter
>brake fluid
>PAS fluid
you may want some ramps to get under the car, container for the oil
oil filter removal tool!
new drain plug maybe needed.
thats just the basics, dont think i have missed anything?
Offline yorkshire_gti
« Reply #6 on: 18 August 2009, 15:28 »
just thinking the same myself....
ive got a 1995 mk3 1.8 convertable with a AAM engine....
anybody know where the fuel filter is and is it easy to change?
all the other bits are no problem
« Last Edit: 18 August 2009, 15:33 by yorkshire_gti »
adamrob69
« Reply #7 on: 18 August 2009, 15:35 »
pollen filter is under the scuttle panel where yur wipers are, easy to get off, and the filter is on passenger side. easy.
fuel filter i THINK! is near the fuel tank under the car.
Offline Adam
« Reply #8 on: 18 August 2009, 15:38 »
Fuel filter is on the drivers side just infront of the rear wheel.
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #9 on: 18 August 2009, 17:20 »
A garage service is normally:
Plugs (unless high mileage plugs)
Oil + Filter (never one without the other)
Air filter
Pollen filter (if applicable)
Screen wash
Brake fluid
Belt checks
PAS fluid
Engine coolant
Grease doors up
Tyre pressure
Fuel filter (if needed)
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
