Author Topic: How To 'Zero' Boost Gauge Needle  (Read 7476 times)
Offline northeast_gti-t
  • "1.8T AGU"
« on: 07 June 2009, 11:14 »
Well as one or two of you have the 'newsouth performance indigo' boost gauges fitted i'm sure you will find as i did that the needle doesn't rest at zero  :sad: well T_J_G also asked me how i got mine sat at 'zero' and i found this which could be of use : http://uk-mkvs.net/forums/p/128471/864415.aspx#864415
i used this earlier in the week and used a small thin blade screwdriver and lightly pressed the brass capillary tube 'past' the zero approx reading 2-3 psi started the engine let it settle and then turned off to check for sitting at zero if it was slightly out i re-adjusted to suit it took me 3 tries to get mine to sit at zero but it reads zero now  :smiley: so hope this helps others out to
« Last Edit: 08 September 2009, 23:09 by richw911 »
2000 Mkiv GTi 1.8T AGU
Offline T_J_G
Re: How To 'Zero' Boost Gauge Needle
« Reply #1 on: 07 June 2009, 17:32 »
Hmm mines the one that goes loads of different colours and don't remember a sticker on it when I removed it. I shall look at some point.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 07 June 2009, 20:50 »
mine didn't have the hole on the back either, I had to drill a dirty great hole in the casing lol
Offline BaV
  • 2001 Golf GTI 1.8T AUM
« Reply #3 on: 09 June 2009, 22:32 »
You can move the neede by twisting the brass fixing that the vacuum tube fixes to  :smiley:
Offline T_J_G
« Reply #4 on: 23 July 2009, 10:15 »
You can move the needle by twisting the brass fixing that the vacuum tube fixes to  :smiley:
I can't on mine. Do you mean the threaded bit or the bit that screws onto the threaded bit?
Offline BaV
« Reply #5 on: 23 July 2009, 22:43 »
Either one.  It does feel hard though so i could understand why people say you cant and also feels like you are going to break it off! but i have done it on more than one mate and works a treat because you can get it dead on
Offline T_J_G
« Reply #6 on: 25 July 2009, 11:01 »
Job for you at brands then!
Offline BaV
« Reply #7 on: 26 July 2009, 23:07 »
Lol knowing my luck i will break urs!
