Author Topic: Changing rear axle bushes  (Read 33353 times)
Offline Mr Blue
Re: Changing rear axle bushes
« Reply #30 on: 17 September 2009, 12:18 »
Ive read that Seat bushes give a much firm ride so I changed mine for standard VW ones @ £18 each
You will need to take off the rear axel if you dont have a ramp.
Its better to take the axel off anyway...paint it and stick it back on. I cant see how someone can get the bushes back in with the axel in place. They dont go in THAT easy :rolleyes: (without a ramp)
Clamp the brake lines before you undo the pipes! (i used small G clamps)
If you get air in the ABS pump you will need VAG.com to sort it (so ive read)
You will need to burn/heat the old bushes and tap them out with a hammer.
Rear bushes... probably the easiest thing ive changed on a mk4 golf. You dont need a press. You just need some sort of 'wind in' tool (made my own)
Total cost just under £200. That was with new vag shocks too so check those while your at it!
Hope that helps
« Last Edit: 17 September 2009, 12:23 by Mr Blue »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #31 on: 17 September 2009, 20:07 »
did all mine in situ, took 6 hours mind  :grin:
Offline Mr Blue
« Reply #32 on: 17 September 2009, 23:18 »
yeh you could do it in situ but for the sake of a few hours. sod that :laugh:
And burning the old bushes out wouldnt be a good idea next to the fuel tank :grin:
« Last Edit: 17 September 2009, 23:20 by Mr Blue »
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #33 on: 17 September 2009, 23:54 »
i ordered my vrs ones today, i was reading somewhere and it said that they have to be positioned correctly when installed is this true if so anyone know how and where/what to line it up with
Offline Mr Blue
« Reply #34 on: 18 September 2009, 12:14 »
yes. check out the vortex thread
http://forums.vwvortex.com/zerothread?id=1980960
I went by the number (2) being closest to the tarmac and has been ok. One was a few mm out of line but still went back on the car ok and have had no problems with handling.
Offline Steve_PD
« Reply #35 on: 18 September 2009, 13:23 »
but the vRS ones are solid rubber and have no voids or a positioning marker
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #36 on: 18 September 2009, 13:57 »
yes they do, bear with me and I'll find a pic for you
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #37 on: 18 September 2009, 14:10 »
 :wink:
Offline G60GTI16V
« Reply #38 on: 18 September 2009, 21:22 »
there the ones i just picked up today but do u use the green line to line it up to the mark 2 on the diagram? and im thinking this is the part of the arm thats facing the ground not the underside of the car?
« Last Edit: 18 September 2009, 21:27 by G60GTI16V »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #39 on: 18 September 2009, 21:26 »
you got it mate  :wink:
