Author Topic: Centre console / ciggy lighter removal  (Read 2086 times)
Offline benjo
« on: 07 May 2009, 18:08 »
Keeps blowing fuses, so i'm trying to disconnect the lighter. How do i get the lower panel off so i can get behind the cigarette lighter?
Offline Mr Blue
Re: Centre console / ciggy lighter removal
« Reply #1 on: 07 May 2009, 18:24 »
two philips screws each side of the centre console that hold the dash trays up
one screw under the gear gator. It should then slide forward and out.
Cig lighter plug removed and walla
EDIT: I remember having this fuse problem. It was a mix of wrong fuses and too much things that ran off the cig lighter feed.
« Last Edit: 07 May 2009, 18:32 by Mr Blue »
Offline benjo
« Reply #2 on: 07 May 2009, 22:25 »
Thanks mate, managed to get it off and unplug the lighter. No more blowing fuses  :wink:
Car will just have to go without a cig lighter for now :)
Offline Ben Lessani
« Reply #3 on: 08 May 2009, 10:22 »
Just run a new wire from the fusebox on the IGN live? That way you can still have your cig lighter - you might not need it now, but knowing sods law ...
Offline benjo
« Reply #4 on: 08 May 2009, 15:01 »
Well it's my mates Mk2, and I'm sure he'll want it for his phone charger, so we'll look into it :)
Thanks
Offline Ben Lessani
« Reply #5 on: 08 May 2009, 15:14 »
I take it your current cig lighter internals are bent and it is shorting?
Offline benjo
« Reply #6 on: 08 May 2009, 15:16 »
Not sure mate, I just pulled the plug out from behind it and then tried a new fuse. It didn't blow so we've left it at that for now.
Going back to it after the weekend so i'll see what was causing it  :smiley:
Offline satchyy
« Reply #7 on: 20 July 2018, 02:30 »
Mr Blue, I don’t even care how old your post is, thank you so much for this!! The rest of the internet was slightly less helpful
« Last Edit: 20 July 2018, 02:32 by satchyy »
