Author Topic: My site all about the Mk3...spec, engine info and more  (Read 33788 times)
Offline boneybradley
  • Moderator
  • Back in a Mk3...
    • Golf Mk3 info site
Re: My site all about the Mk3.. spec,engine info and more
« Reply #20 on: 25 February 2009, 23:55 »
Lots of pictures added today (cl, gl tdi, gti, concept, anniversary etc)...
Can i have comments on
1. What else would be usefull on the site (other spec info etc)
2. Does the site look ok and is it easy to navigate? (exc any adverts as its a freebie at the mo)
Offline Shady Pioneer
  • Moderator
  • graphic designer.
    • pixelements
« Reply #21 on: 25 February 2009, 23:59 »
Nice, you used my pics, I'm famous. I will say one of the pics from the rear you got of mine has the GTI rear lights I put on, dunno if you noticed that or not?
Also are you able to change the top banner because I could make you a banner at some point if you wanted?
[/center]
Offline shepgti
« Reply #22 on: 26 February 2009, 07:39 »
loads more engine spec listed (outputs for all modles and relevant info and wheel info are now up)... I still lemans and vr6 wheel pic's tho  :wink:
ive got leman wheel pics if you still need them, got car at standard height too..
EDIT: i see youve already got them  :wink:
Offline shepgti
« Reply #23 on: 26 February 2009, 07:54 »
Could stick up some info regarding wheel fitment/offset for gti and non-gti models in the wheel section.
Offline Len
« Reply #24 on: 26 February 2009, 08:12 »
Only had a cursorary glance so far but will have a good browse tonight and give ya my views!  :wink:
Mystic Blue Mk3 16v + Passat 1.8T Sport + Peugeot 405 Mi16
www.sas.org.uk
www.the-ace.org.uk
  • 2006 Peugeot 307 Cabrio
« Reply #25 on: 26 February 2009, 08:57 »
Also the rear spoiler is non standard.
  • Moderator
  • graphic designer.
    • pixelements
« Reply #26 on: 26 February 2009, 09:04 »
It was nonstandard but it was an extra when bought. :)
[/center]
Offline Dec
« Reply #27 on: 26 February 2009, 09:10 »
I like it mate :)
With some added fancy effects + flash I think you will have a winner :)
Content is all there though, and it works, so no need to change it unless you want it made to look fancy :wink:
Offline LostBok
« Reply #28 on: 26 February 2009, 12:22 »
i'll get some pics of mine over the weekend...
LOSTBOK
Audi A4(B6): 2.5TDi Quattro Sport: Factory fitted Xenons, BOSE, and full sports leather "Soul Black / Titanium".
Mods: All OEM: S-Line bodykit, RNS-E, Bluetooth, Audi R8 FBMFSW, SDS-High voice control, full DIS, cruise control, Aero wiper mod.
In progress: 5 x OEM S4/Ronal 'Avus' 18's & 235/45ZR18 Toyo Proxes T1-R (bah! wheels delayed until WC 27-JUL-09)
Researching: Colour DIS, Freeview and DAB tuner with iPodvid/PSP/AV in for the RNS-E.
  • Moderator
  • Back in a Mk3...
« Reply #29 on: 26 February 2009, 13:04 »
well here's the wheel guide I'm going to use
VW Mk3 Golf Wheels..
Steel
5.5x13 ET38 4/100 13"
6.0x14 ET43 4/100 14"
6.0x14 ET45 4/100 14"
6.0x15 ET38 5/100 15"
6.0x15 ET35 5/100 15"
6.5x15 ET43 5/100 15"
3.5x14 ET45 4/100 14" Temp
3.5x15 ET38 5/100 15" Temp
3.5x16 ET38 5/100 16" Temp
Alloy
6.0x14 ET45 4/100 Orlando
6.0x14 ET45 4/100 Imola
6.0x15 ET45 4/100 Imola
6.0x15 ET38 5/100 Le Mans
6.5x15 ET43 5/100 Solitude
6.5x15 ET43 5/100 BBS
6.5x15 ET43 5/100 Long Beach
6.5x15 ET43 5/100 Monte Carlo
6.5x15 ET43 5/100 Brands Hatch
6.5x15 ET43 5/100 Speedline
7.0x16 ET43 5/100 BBS RXII
What does PCD mean?
PCD stands for (pitch circle diameter), this is the diameter of a circle drawn through the centre of your wheel's bolt holes. PCD is measured in millimetres and also indicates the number of studs or bolts the wheel will have. The most common fitment has 4 studs with a PCD of 100mm, hence the fitment 4x100.
What does OFFSET (et) mean?
Your car requires a unique offset. This is where the wheel will sit in relation to the bodyline of the vehicle, realistically you can go 5-7mm outside these recommendations. Offset is usually stamped on the wheel and is measured in millimetres of et (et is the short form of the German word 'Einpresstiefe' which literally translates as insertion depth).
If you disagree with any of the fitments please reply in this thread and I will ammend as needed  :wink:
