Author Topic: The ICE Bible  (Read 60918 times)
Offline Dizzie
  • Make friends with your fast
The ICE Bible
« on: 04 July 2004, 15:31 »
I've kinda had this idea where we can all add things that we're 100% certain on and build up a comprehensive guide of things to do and not to do when installing and setting up our car stereos.
it'd be filled with loads of little things like advice on choosing speakers to placement of tweeters to give the best sound.
I don't claim to be an expert on sound or installing car stereo equipment, but I'm sure together we can make a nice little 'bible'. If you're 100% sure on something reply to the thread. Please don't reply and start a discussion about something someone else has posted previously. I'll try and keep it as neat and tidy as I can.
« Last Edit: 05 July 2004, 23:54 by Dizzie »
Mk4 Golf 150PD
VeeDubGTI16v
Re:The ICE Bible
« Reply #1 on: 04 July 2004, 19:42 »
seperate RCA cables from power cables, ummm ??? 18mm mdf for parcel shelves  :D
that sort of stuff dizzie?
Offline Dizzie
Re:The ICE Bible
« Reply #2 on: 04 July 2004, 21:16 »
exactly </westwood>
Loudness is measured in decibels, not watts!
Mk4 Golf 150PD
Offline AdamB
  • The Perfect Storm
Re:The ICE Bible
« Reply #3 on: 04 July 2004, 22:04 »
exactly </westwood>
a 3 decibel increase is double.
i.e a speaker running at 100db placed along side another running at 100 db does not equal 200db, only 103db.
its all logarithmic.
2 x power = 3db increase
10 x power = 10db increase
100 x power = 20db
1000 x power = 30db, etc, etc...
And always ensure the earth cable can handle as much current as the +ve cable providing the power
I don't own this anymore - I just can't be arsed to change the picture
VeeDubGTI16v
Re:The ICE Bible
« Reply #4 on: 20 July 2004, 18:04 »
try and solder every connection (permanent ones obviously) instead of using spade connectors etc
when earthing make sure you get a good connection by sanding the metal a little before clamping the earth wire on
always put the fuse for amps by the battery and not by the amp. it may look good but you want the surge stopped as close to the battery as possible.
dont poke the speakers through the parcell shelf, they will only get stolen >:(
Offline Dizzie
Re:The ICE Bible
« Reply #5 on: 20 July 2004, 22:35 »
I hear somewhere that you should really put a fuse on both ends of you power cable. The amps will have stored power in them so could cook if there's a short through the firewall in the event of a crash.
More important if you're using a power cap too.
Mk4 Golf 150PD
Offline MarkII16v
Re:The ICE Bible
« Reply #6 on: 26 July 2004, 09:13 »
The fuse connected to the power cable should be a maximum of 18inches from the battery terminal so as to stop the surge as quickly as poss. (As mentioned by veedubgti16v)
« Last Edit: 26 July 2004, 09:14 by MarkII16v »
Offline Colin
Re:The ICE Bible
« Reply #7 on: 27 July 2004, 13:43 »
Use a bigger amp than necessary and run it gently.
Don't use a small amp on big speakers, they'll suck all the guts out the amp.......literally.
If you don't understand wiring, don't play with it, you'll only end in tears.
And finally "THE ONLY MEASUREMENT OF POWER IS WATTS RMS"!!!!!
Any other measurement is a hyped up mickey mouse figure and if your supplier can't quote "RMS" power then go buy something else, trust me !
Offline Dizzie
Re:The ICE Bible
« Reply #8 on: 06 August 2004, 23:57 »
Smaller subs are punchier so handle dance music better.
Larger subs prefer r'n'b styles of music and are generally louder and handle more power than the smaller speakers.
A Sealed enclosure creates a tighter note whereas a port enclosure can be tuned by adjusting the length of the port to suit. Many subs quote figures in both a sealed and ported enclosure and give buyers the flexibility to use in both ways.
Mk4 Golf 150PD
Offline GavG60
  • keep my credit cards away from me please :-(
Re: The ICE Bible
« Reply #9 on: 24 August 2004, 11:46 »
if you're planning on having anything more than 4 speakers and want any where near decent sound - you need an amp.
Attempting to run six speakers plus two tweeters on a normal head unit will cause it to overheat and seriously compromise sound quality
(guess who's just discovered this set up in his car)
